Results 1 to 8 of 8
Thread: Rear Axle
    Mar 2004
    Rear Axle
    My C Record rear free hub axle is bent. I'm looking for a replacement on eBay. Are the rear axles pretty much universal. If my rear spacing is 126 mm what should I get as far as a length 128, 130?
    Reputation: velodog's Avatar
    Sep 2007
    Too old to ride plastic
    hfc
    hfc is online now
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    Freehub or freewheel hub? If you let me know a ballpark year or post a pic, I can look through some of the parts catalogs I have to see what they look like.
    Mar 2004
    Quote Originally Posted by hfc View Post
    My bad. Freewheel hub. Around 86, 87.
    Sep 2007
    Sutherland's 4th edition(1985) has these dimensions for a Campagnolo axle
    Thread--10mmx26TPI
    Over locknuts--125mm
    Axle length--134mm
    Dimension A--35mm (this is the measurement from the shoulder that the freewheel buts up against to the outside face of the axle locknut)
    Chainline--43.5 (from center of the hub to middle of the mounted freewheel, which would be the center cog on a 6spd freewheel.)(Do Not put the freewheel on a hub that isn't built into a wheel, Big Mistake. You probably know this, but I thought that it's worth mentioning.)
    hfc
    hfc is online now
    Jan 2003
    I dug out my Campy catalog 18 (Super Record, Record and lower groups pre 1985) and 18 bis (C Recd, Victory, Triomphe groups) . The part number for the C Record and Record rear axle is the same , 29/R. Listed as 132 mm in catalog 18 whereas no axle lengths listed for any hubs in 18 bis.
    Nuovo Tipo hub in cat 18 is listed as part 29 , 127 mm long. Axles for Triomphe and Victory Hubs are part # 420/004.
    Nov 2014
    Check Wheels MFG to see if they have one for you. There axles are very good.
    Mar 2004
    Thanks for the research. I'll either get the one in Boulder, but I'm checking one other source as I don't need any of the other hardware.
  1. setting up rollers -- front roller axle vs front hub axle
    By teleguy57 in forum Racing, Training, Nutrition, Triathlons
    Last Post: 01-03-2009, 06:39 PM
  2. Replies: 5
    Last Post: 06-25-2005, 12:51 PM
  3. Bent rear axle ? - Diagnose please
    By Flying Irishman in forum Components, Wrenching
    Last Post: 02-07-2005, 05:15 AM
  4. 2nd broken rear axle.
    By Spinfinity in forum Fixed/Single Speed
    Last Post: 10-01-2004, 04:02 AM
  5. Can I get a quick lesson on rear axle width and dropouts?
    By DreaminJohn in forum General Cycling Discussion
    Last Post: 05-17-2004, 09:08 AM
