Results 1 to 7 of 7
    Those ferrules on cable housing?
    the brake cable ferrule is metal, and the shifter cable ferrule is plastic.
    do these go on the ends that fit into the brake/shift lever body? where the cable originates from?
    or is that end of the cable housing left bare?
    also, the end of the brake cable housing that fits into the caliper brake doesn't fit with the metal ferrule, only bare cable fits. is this correct?
    thanks
    edit: for record 10-speed if it matters
    Reputation: nova_rider's Avatar
    Sep 2005
    Quote Originally Posted by Speed_Metal View Post
    thanks
    Do not use ferrules for the shifter/brake body or the caliper for Campy
    Sent from my XT1575 using Tapatalk
    Quote Originally Posted by nova_rider View Post
    thanks for the info
    Jan 2010
    Actually that last answer is only 1/2 right.
    Campy 10-spd Record does use ferrules at the shifter body and at every other derailleur cable end. (this was changed for 11-speed).
    Brake housing does not require ferrules anywhere.
    You should be using Campy cabling which comes with metal ferrules. Or at least Campy-compatible. Not just any old cable. The ends are different.
    There's sometimes a buggy.
    One.
    Sep 2005
    Quote Originally Posted by bikerjulio View Post
    I thought OP was inquiring only about brake housing. Plastic shifting ferrules suggest non-oem Campy cableset, which may not fit into the s​hifter body.
    Jan 2010
    He was asking about both, and my answer covered both. Possibly he has a Campy compatible set that has plastic ferrules, which would be OK, or a non-compatible set which would not be OK. Who knows?
    One.
    they might be jagwire housing, but as far as i know the cables are campy. but my question was answered.
    thanks
  1. 4mm housing ferrules don't fit
    By jdave5917 in forum Components, Wrenching
    Last Post: 10-25-2016, 11:46 AM
  2. Housing ferrules on internally routed Izalco?
    By andy13 in forum Components, Wrenching
    Last Post: 03-07-2014, 07:28 PM
  3. Campagnolo 10 speed build question - ferrules, cable housing
    By rolinox in forum Components, Wrenching
    Last Post: 06-28-2009, 08:42 AM
  4. metal cable housing ferrules?
    By Qstick333 in forum Components, Wrenching
    Last Post: 05-23-2008, 06:32 PM
  5. Ferrules for Shift Cable Housing
    By the_gormandizer in forum Components, Wrenching
    Last Post: 09-13-2006, 09:16 PM
