Results 1 to 12 of 12
Thread: Torque Spec
    Mar 2004
    Torque Spec
    For self extracting crank bolt. Do you have or use one or just get it "tight"?
    Dec 2006
    Shimano crank bolts are spec'd at 305-391 inch-pounds. The Shimano cap which the self-extracting pushes against for release, is 44-60 inch pounds.
    If you're thinking self-extracting bolts run a different spec than standard bolts; no difference.
    Mar 2004
    I'm thinking torque spec are based on Fastener size and material, which may vary from manufacturer to manufacturer, model to model.
    Which I dead mean but failed to mention, early C Record.
    tka
    tka is offline
    Jun 2014
    32-38 Nm if memory serves me right.
    Nov 2014
    I have 312-324 in lbs from Park Tool, 32-38Nms from Campy.
    Reputation: velodog's Avatar
    Sep 2007
    Grease or dry on the tapers of the BB spindle?
    Too old to ride plastic
    Mar 2004
    I've been debating that myself.
    Jan 2010
    I've always used grease.
    With my torque-sensitive hands I tighten to "pretty damn tight" with a hex key, then go for a ride, and then check tightness again.
    C Record is the same thread on the bolt, just the head is smaller. So torque would be the same as with other Campy square taper cranks.
    There's sometimes a buggy.
    One.
    Sep 2007
    Quote Originally Posted by bikerjulio View Post
    I do dry, but to pretty much the same torque specs as you.
    Nov 2014
    Pretty sure Campy calls for dry.
    Jan 2010
    Quote Originally Posted by GKSki View Post
    I think you are right. Just can't bring myself to do it.
    I believe the logic is that if you are doing crank swaps frequently, the lubrication will permit the crank to go on the taper marginally further, and therefore increase the "stretching" force on the crank, and decrease the number of times the crank can be installed without bottoming out.
    If one is doing a one-time, long term install then I still think grease is OK to prevent things freezing up.
    One.
    Sep 2007
    Years ago I used to grease the tapers, and I developed a creak I couldn't locate. A friend suggested I remount the crank arms dry, and when I did the creak was gone. I've been running them dry since.
  1. Expander plug torque spec
    By Stumpjumper FSR in forum Specialized
    Last Post: 04-10-2011, 06:52 AM
  2. Torque spec: 566 seatpost binder
    By s30.hybrid in forum Look
    Last Post: 03-20-2011, 09:25 PM
  3. How to Tighten Lockring to Torque Spec?
    By HammerTime-TheOriginal in forum Components, Wrenching
    Last Post: 01-28-2007, 07:09 AM
  4. Giant Manufacturer torque spec
    By Shane in forum Giant
    Last Post: 01-11-2005, 11:58 PM
  5. General Torque Spec guide?
    By lsnfa in forum Components, Wrenching
    Last Post: 09-24-2004, 11:12 AM
