Results 1 to 20 of 20
    Reputation: ARPRINCE's Avatar
    Feb 2011
    Cannondale Hallowgram SL BB30 for Synapse Alloy 5
    Hi,
    My Synapse Alloy 5 uses an FSA Gossamer BB30, 50/34. I want to upgrade to a Cannondale Hallowgram SL BB30 50/34 170mm. Do I need to change the bottom bracket too? If not, is this upgrade something I myself can do easily?
    TIA
    Converted Runner
    Reputation: aengbretson's Avatar
    Sep 2009
    You shouldn't need to change the BB. If you have basic tools it should be easy enough. Don't hit the crank too hard on removal of the old or installation of the new because the bearings aren't supposed to handle side loads.
    Feb 2011
    Quote Originally Posted by aengbretson View Post
    Good to know. I guess I just need the proper tools to do this myself. Thanks!
    Feb 2011
    Crank puller recommendation
    Looking for a recommendation for a crank puller tool - thanks.
    CHL
    CHL is offline
    Naso Unicornis
    Reputation: CHL's Avatar
    Jun 2005
    ARPRINCE:
    You will need the Cannondale extraction tools and Hollowgram spindle. Cannondale usually sells the spindle accompanied by the bearings (steel ~$100 or ceramic ~$180). Bearings are loaded by a wave washer and a set of spacers. If you put too many or too few spacers, you will need to remove the crank arm (hence the extraction tool).
    FSA BB30 cranksets are easily removed. Remove the non drive side arm and push the spindle out of the bearings. FSA cranksets have self extracting bolts, while the Hollowgram SL does not. You can use your old bearings, if they have not worn out.
    chl
    2015 SS6 Evo HM - Sram Red/Force
    2012 Slice 5 - 105/Sram Red
    Feb 2011
    Quote Originally Posted by CHL View Post
    ARPRINCE:
    chl
    So I need this one...
    http://www.cannondaleexperts.com/Can...013_p_124.html
    And this one...
    http://www.cannondaleexperts.com/Can...612_p_198.html
    OK. So I thought it was just a matter of removing the cranks and replacing it with the HALLOWs. It's good to know. I might just bring them to my LBS - thanks.
    Feb 2011
    Quote Originally Posted by ARPRINCE View Post
    Hi,
    TIA
    So I decided to just order it from my LBS and have them install it. I ordered it last week and it arrived last Monday (after informing me that it was a 2 week wait). Anyway, I went there today to drop off my bike and check out the Hollowgram crank. Can't wait to use it this weekend.
    I did notice that the biggest ring, the teeth are not symmetrical. There are edges that they look smaller then grows bigger. If you look at the picture below, you'll notice it on the upper leaft biggest ring and lower right (just below the HOLLOWGRAM and above the 50T markings). Is that normal?
    CHL
    CHL is offline
    Naso Unicornis
    Jun 2005
    This is perfectly fine and is quite common across all chain-ring manufacturers. My MK-V, Specialites TA Hegoa and DA7701 chain-rings all have these. I believe it assists in shifting.
    Waiting on my lock ring to install Hollowgram SL onto my CAAD9. Bye bye FSA (nothing wrong with them but the Hollowgrams are superior).
    C.
    Feb 2011
    C.
    Thanks. I also confirmed from my LBS that it is by design.
    Feb 2011
    Got it!
    I got my bike today.....sweet!!!!!
    I had my handle bar tape replaced too but they did not charge me anymore.
    Reputation: CAADEL's Avatar
    Jul 2011
    Hi,
    Hey,
    I also want to upgrade my CAAD10-5 (FSA Gossamer BB30, 50/34 too) with an alloy hollowgram SL 50/34 172.5 and I was wondering how much did it cost you.
    After the upgrade how different did you feel the pedaling was?
    Thanks!
    Feb 2011
    Quote Originally Posted by CAADEL View Post
    Hey,
    Thanks!
    $845 with the BB and price includes install ($900 for the ceramic BB). Really stiff with a very good power transfer response (and lighter too!).
    fu
    Reputation: ph0enix's Avatar
    Aug 2009
    I'm curious what prompted the upgrade. I thought perhaps you got a great deal on the crankset and couldn't pass it up but that's clearly not the case. Now your bike has a way better crank than the rest of its components. Obviously it's your bike and your money but the ride is a bit mismatched, IMO. I would have spent the $$$ on better wheels instead. Sorry if I'm raining on your parade - just speaking my mind. Don't let me tell you what to do.
    My other chainring is a 39...
    Strava profile
    Jul 2011
    Thanks for your answer! Did you buy the BB extra or is it included in the box? Another user said you could use your old one and I wonder why did you replace it.
    If I could buy it in pieces (left and right arm) and use my old fsa gossamer chainrings for some time until I can upgrade them too would be great and make my purchase more affordable. Is this possible or am I asking too much?
    Feb 2011
    All included
    I asked Cannondale and they got back to me with the answer below so I decided to just buy everything (Hollows, spindle, bearings @ $840) rather than find out later that I needed this/that.
    "If you are going to run a Cannondale Hollowgram SL crank then you would need to run the Cannondale Hollowgram bottom bracket. Your local Cannondale Retailer can further assist in getting what you need and for proper setup."
    Feb 2011
    Quote Originally Posted by ph0enix View Post
    You are right! I really wanted to get a CAAD9 but could not find one for my size. I'm thinking I have a awesome crank if ever I decide to upgrade my bike.
    On the other hand, I upgraded my wheels too (valleycyclist) - to match it!.
    KINLIN XR300 24/28 Black
    Front Hub White Ind H2 24 Black
    Rear Hub White Ind H3 28 Black
    Spokes Sapim CX Ray Black Aero
    Spoke Nipples Alloy Blue
    Continental GP 4000s
    fu
    Aug 2009
    Those are very solid wheels! My ROL Race SLs use the same rims and spokes. Going from the RS10's to those made a huge difference in the ride, I'm sure. Enjoy!
    P.S. I think my next wheelset will come from Zen Cyclery - thinking carbon.
    Strava profile
    Aug 2011
    How do you like your Alloy 5.. Im debating between the Alloy 6, 5, and Carbon 6.
    Feb 2011
    Smooth ride
    Quote Originally Posted by MiamiHeat View Post
    My stock Synapse was a pretty decent ride. Since it is considered to have a more relaxed design compared to a CAAD10, I decided to get one since I have not ridden a bike regularly for a very long time. Get really good wheels and feel the bike transform and perform to a whole new level. The RS10s that came with my stock bike were average at best. Prior to gettting my bike, I visited forums and asked friends. They say at a minimum, get a 105 groupset. If I'll do it all over again, I would have just probably bought a frameset and build from there on. I would have loved to get my hands on a CAAD9 USA frameset. Ohhh well....
    Sep 2011
    I have a CAAD 10 and was thinking about buying a Hollowgram crankset but they are indeed expensive - yikes!
  1. 2011 Cannondale Synapse 5 Alloy 105 Ride Report
    By 8toes in forum Bikes, Frames and Forks
    Last Post: 08-13-2011, 08:34 PM
  2. Cannondale Synapse Alloy 105 or Carbon Tiagra?
    By SBR812 in forum Women's Cycling+
    Last Post: 12-12-2010, 08:17 PM
  3. How much weigh your Cannondale Synapse alloy?
    By jesusaa in forum Cannondale
    Last Post: 02-21-2009, 11:54 AM
  4. Any experience with Cannondale Synapse Alloy?
    By cooperworks in forum Cannondale
    Last Post: 02-27-2006, 01:36 PM
  5. Replies: 31
    Last Post: 10-02-2005, 01:04 PM
