Results 1 to 9 of 9
    Jun 2012
    EVO FORKS - Carbon steerer tube wear.
    Hi All
    I am wondering if any of you mechanics out there have experienced this.
    I have an Evo Hi-Mod. The steel headset compression split ring has a razor sharp edge on the inside. As a result of this compression on the carbon steerer tube the steel ring has worn a lovely groove around the carbon steerer. Steel hard - Carbon soft = wear
    Before everyone chimes in with a reason why let me explain the headset was not allowed to get loose, and was never overtightened. It is not until complete disassembly that the damage can be seen.
    This is now an unusable fork for the time being due to safety concerns regarding potential breakage under severe handlebar load.
    I have seen this on several Evo's but this is the most extreme damage.
    Your thoughts?
    Attached Thumbnails Attached Thumbnails EVO FORKS - Carbon steerer tube wear.-img_0560.jpg   EVO FORKS - Carbon steerer tube wear.-img_0556_2.jpg
    Apr 2006
    I will inspect an EVO himod in our group to see if the same thing has occurred and report back. I can tell you that the headset on this bike was very difficult to get right. I needed to add several micro shims so that the frame didnt interfere with the correct setting of the preload on the headset. Without the shims, it would tighten down, but not put sufficient preload on the bearings and the headset would remain loose. You may want to check that.
    LA CHEVRE
    Reputation: Dan Gerous's Avatar
    Mar 2005
    I have seen the compression ring kind of polishing steerers but not wearing into it like that. My first guess was it's overtightened, but... Was the ring hard to slide onto the steerer? It should be snug but still easy to slide it down.
    Good idea to check goodboyr's suggestion that it 'could' be that the frame stops the preload you can put... but if it was the case, the compression ring would not be too tight but too loose so I'm not sure it could do such damage... unless the wear is from some play so the steerer and ring can rock into each other constantly, but then I'd think you'd feel the looseness.
    DAN GEROUS
    : ROAD
    : CYCLOCROSS
    : MOUNTAIN BIKING
    Reputation: macca33's Avatar
    Oct 2012
    Wow - not cool at all.
    I have 2 x CAAD10s with carbon steerers and have never seen this - usually pull the headset to re-grease twice a year.
    I reckon it may have been overtightened myself - but it is difficult to say from pics alone.
    cheers
    2011 'dale CAAD10 Berzerker - Ultegra6800 - for the serious stuff
    2012 'dale CAAD10 Team - Ultegra6800 - with compact for the hilly bits!
    Jul 2011
    If you had not said it was not overtightened, this is exactly what I would have suggested. Why it that piece rotating with the the bearing and not on the steerer?
    Or do you think it may be from rocking from sprinting forces and steerer flex maybe?
    Shows the importance of the inspections to be sure!
    Quote Originally Posted by Robt57/Me!
    Everything you read that I post is just '1' guy's opinion, try to sort it all out best you can. ;) I will try to add value in my posts, if I miss the mark please let me know using a little decorum.
    Jul 2011
    Hey I've got the same issue. My bike is in the shop now and the latest is they can't find a matching fork. Mine is a 2012 supersix evo
    Jun 2018
    This is from my 2012 Trek Madone 5.2. Same groove and about the same size. Could this be a bearing or bushing issue?
    Jun 2012
    That is exactly the same problem. The aluminium spacer wedge (silver ring in my photo above) has worn a groove around the steerer tube. Depending on the thickness of the carbon steerer tube this could be the end of those forks. Darn it !!!
    Apr 2006
    Just assembled a caad12 disc frameset and it had a plastic compression ring.
    I can check my 2018 evo and 2018 superx too.
    I have seen this before, mostly on loose headsets i think. The worst i saw was on a Focus that the person basically always rode with a loose headset.
  1. Carbon Forks...carbon steerer tube vs. aluminum?
    By durkind in forum Bikes, Frames and Forks
    Last Post: 08-23-2007, 04:58 PM
  2. Steel-Steerer Carbon Forks...
    By Argentius in forum Bikes, Frames and Forks
    Last Post: 02-01-2007, 09:48 AM
  3. carbon forks with a metal steerer tube
    By tigoat in forum Bikes, Frames and Forks
    Last Post: 10-24-2006, 04:07 PM
  4. Carbon Steerer Forks
    By James A in forum Cyclocross
    Last Post: 01-05-2006, 10:39 PM
  5. carbon forks: full carbon vs. one with alu crown and steerer
    By DaveloMA in forum Bikes, Frames and Forks
    Last Post: 01-05-2006, 03:06 PM
