Results 1 to 4 of 4
    Reputation: shotojs78's Avatar
    May 2008
    bike fit look wedge
    hi, I bought that : http://www.bikefit.com/products.php , cause I have a problem with my right leg.. knee vs foot alignment. So I have too many pressure on the outside, so I tought I would need to put the thickest part of the wedges on outside but on I read that we need to put that on the inside.... so if I put 2 wedges, I would like to know if I need to put 2 the other side, 1 with the thick side inside and 1 with thick side outside.. do you undertsand?? if not my left leg will be shorter than the other..
    __________________________________________
    2012 Cannondale Super Six EVO (sram red)
    2012 Cannondale caad 10 (sram)
    2010 Cannondale super six HM liquigas (sram red) sold
    2009 Cannondale caad 9 BB30 Team (sram red)
    2008 Cannondale caad 9 (dura ace) sold
    2007 Cannondale caad 8 (ultegra) sold
    2007 Cannondale six 13 team bb30 (sram red)
    2006 Opus vivace (ultegra) sold
    Jun 2010
    Yes, presuming your legs are the same length to begin with (might not be the case), you'll want to add a "neutral" stack to the other foot of equal height, then slightly increase your saddle height.
    If you haven't invested in a good custom footbed, or at least one that has been picked to fit your foot type (i.e. BG Specialized Footbed), I would do so before going with the wedge option.
    May 2008
    I have the superfeet insole in my R310 shimano
    Jun 2010
    Used these wedges and yes you put the thick part in. It will no lengthen your leg significantly. I started with 2 and ended up adding a third. Easy to do just remember your cleat angle. Helps significantly and allowed use or continued use of look cleats, instead of switching to speedplay.
Sea Otter Classic
Contest
