Results 1 to 7 of 7
    Reputation: Srode's Avatar
    Aug 2012
    Golden Cheetah - Entering Weight
    I see weight as an option under the metrics tab on Golden Cheetah but no place to enter it. I assume this is the rider weight, anyone know where to input it?
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Aug 2012
    Aerobic Decoupling
    Just got a power meter rear wheel and have been looking at measures for analysis. I have 3 rides in now with 2 having aerobic decoupling showing below 5% and 1 showing 9%. I'm guessing with the wild swing in results this metric is only valid under certain conditions - perhaps on a time trial the length of your anticipated events / future rides a person is training for, is that correct? These 3 rides are just general rides with the highest TSS being the one with the 9% being the highest TSS which was 189, not stuctured just rides with hills and varied pace.
    Trek Domane
    Trek Crockett
    Feb 2005
    Im not sure this is helpful but I find my aerobic decoupling to be the highest when I'm on a fast group ride coupled with 5,000 feet of climbing. No climbing and I have a relative low decoupling %
    Cycling Coach
    Reputation: Alex_Simmons/RST's Avatar
    Jan 2008
    Now you have a power meter, the best aerobic decoupling is unclipping the HR strap and losing it.
    Aug 2012
    Quote Originally Posted by Alex_Simmons/RST View Post
    So no value in looking at aerobic decoupling as a good indication of when a person is ready to move from base to build? Do you recommend just using time in base for the determining factor?
    I have been using both to help figure out where my FTP is without doing a test. I've done more than one test with HR prior to getting the power meter and have found I am probably in the mid 150s for LTHR and thought that would be a pretty good target over 5-10 minute run to determine FTP. I also had thought that trending lower HR on a hard run, say 20 minutes, was an indication of improving aerobic condition, not valid?
    I was also planning on putting bike with the PT on my trainer to calibrate the speed to power, then take it off and use my aluminum framed bike during the Winter. The aluminum bike has a rear disc brake so didn't want to move the powertap wheel to that bike for use on the trainer.
    Thanks for any tips / advice, just learning now how to use the power meter.
    Trek Domane
    Trek Crockett
    Jan 2009
    There's a mailing list for Golden Cheetah, you might want to ask your question there.
    Anyway, in GC 3: select "Tools" and then "Options". You'll get a new window and on the left you can select "Athlete". "About me" has the item you want.
    Cycling Coach
    Jan 2008
    I have no idea what you mean by base and build, so I cannot answer the question.
    What matters is whether your sustainable aerobic power is improving, and then what goal event specific fitness elements you need to layer on top of that. Neither have much to do with what your HR is doing.
