Results 1 to 7 of 7
    Reputation: mtrac's Avatar
    Sep 2013
    PowerTap Joule in Garmin mount?
    Is there anything available that will allow a Joule GPS+ to use a Garmin mount? I'm particularly interested in the combination Garmin/GoPro mounts. Thanks.
    Forever a Student
    Mar 2014
    If the circle is the same size, which it appears to be, I think the Rec Mounts ones will suit you well. They're a Japanese company with a clever mounting system that fits just about everything. They have both the standard 1/4 turn and also cross 1/8 turn mounting inserts that can be rotated any way you want and screwed down.
    I use the Type 17 personally, which is an out front mount that replaces stem bolts.
    use a torque wrench
    Sep 2013
    Well, that was interesting. I looked at their catalog at http://www.an-y.com/img/rec-mount-catalog3.pdf and also www.rec-mounts.com. Neat product, but I didn't see anything for an 1/8-turn system. I contacted them and received the following.
    Power Tap
    There is no setting.
    There isn't a person who uses it in Japan.
    Catalog
    It's raised in November, 2016.
    But it may be only Japanese.
    Best regards
    Yamazaki
    My original inclination was that PowerTap was keeping third-party mounts off the market, but after contacting two mfrs and doing considerable searching it appears other than the Bar Fly their computer has too little market share to be of interest.
    Forever a Student
    Mar 2014
    Well they certainly do have 1/8 turn mounts, I'm holding three of them in my hand right now. See picture below:
    However looking at the barfly unit it appears as though the powertap mount is 45 degrees off. So this mount would work find holding the unit in a landscape fashion, but it won't work for portrait, like they say.
    use a torque wrench
    Nov 2014
    Nope. PT and Garmins don't work. At least the Joule GPS+ and the Garmin 510/520 mounts I had didn't.
    Sep 2013
    Do you have a part number for those? Thanks.
    Forever a Student
    Mar 2014
    Quote Originally Posted by mtrac View Post
    Yes, I have part numbers, I actually have some from years ago and some very recent.
    The part number for what's pictured is: Type 17
    Type 17 comes with 4 bolts (some longer some shorter), 2 sets of different length spacers to match the bolts, 1 double mount that does the GoPro underneath and the insert on top for GPS units and it includes the GoPro mount attachment. It also includes a few of the insert plates. It should include both 1/8 turn and 1/4 turn ones. I think the one I bought a couple weeks ago had two 1/4 and one 1/8.
    The part number for the 1/8 turn insert is: 1115 (older) or 0415 (newer), they look identical to me.
    You can probably make this work with a Powertap unit provided two things:
    The circle diameter is the same size between Garmin and Powertap
    You drill two new holes and counter sink them just like the ones already there.
    There's 4 holes and screws available for the top mount. You can simply add two more in the blank section between the existing ones allowing you to rotate it 45 degrees. Works in my head anyway.
    use a torque wrench
  1. PowerTap Joule GPS + does anyone have one of these
    By Kendogz161 in forum Components, Wrenching
    Last Post: 12-15-2015, 06:16 PM
  2. Powertap G3 wheelset + Joule 1.0 $640 @ PB
    By tthome in forum Hot Deals
    Last Post: 09-20-2014, 05:27 PM
  3. PowerTap G3 wheelset + joule 1.0 computer ?tions
    By tthome in forum Wheels and Tires
    Last Post: 07-11-2014, 07:12 PM
  4. PowerTap G3 wheelset + joule 1.0
    By tthome in forum Coaching
    Last Post: 07-11-2014, 04:18 PM
  5. Powertap Joule
    By chase196126 in forum Racing, Training, Nutrition, Triathlons
    Last Post: 04-21-2010, 11:25 AM
