Results 1 to 8 of 8
    C59 & 25mm tires
    Question - I am now running some 25mm tires on my C59 - conti 4000 four season. I got to service the bike this weekend and notice at the junction of the two seat stays some paint has come off. It's close with 25mm tires, but are these frames not meant to use 25mm tires?
    I'd be remiss to think so, but wanted to hear other people's thoughts.
    OK, 60 people have read this and no one knows?
    Dec 2005
    I use 25c on mine with no problem. Probably a stupid question, but are your wheels true? Also how wide are your rims?
    Rims are normal DT Swiss 415 - so nothing special there. Wheel is true. It's a tight fit, but there a CM of room. The paint has a rib on it - I'll try to take a picture.
    Dec 2005
    I guess the only thing I would suggest is to make sure it is the tire rubbing the paint and not some other coincidental factor. Also make sure your wheels are in straight in the dropouts.
    Jul 2011
    should have room.
    these are 25mm fmb paris roubaix tubulars and ive got plenty of room. not a ton but enough not to have it rub.
    F@t B@st@rd
    Apr 2010
    Depends on the tire and wheels. I have some 25mm Michelin Pro Optimums on a set of Campag Zonda's (round and true) and they don't fit in there at all...yet my 25mm Vitt corsa evo cx tubs on my lightweights fit fine... Go figure
    Sep 2007
    cale262 is right. I have a C50 and the 25mm tires fit fine, but they did not fit on my Pegoretti. It was trial and error as for as what works with larger road tires for my bikes.
  1. 25mm tires on C50
    By MWT in forum Colnago
    Last Post: 11-07-2012, 04:51 PM
  2. 25mm tires?
    By purplecu22 in forum Colnago
    Last Post: 04-14-2010, 04:19 PM
  3. 25mm Tires ????
    By PinarelloFan in forum Wheels and Tires
    Last Post: 06-05-2008, 01:58 AM
  4. Are 25mm tires slower than 23mm tires?
    By UCLA_MCDbio in forum Components, Wrenching
    Last Post: 08-21-2004, 05:56 AM
  5. Tires -Best 25mm under $30.?
    By breadrunner in forum Components, Wrenching
    Last Post: 03-19-2004, 10:58 PM
Sea Otter Classic
Contest
