Results 1 to 25 of 26
    Jun 2011
    Exclamation Master Piu vs Master Olympic vs Master X light vs Tecnos
    Hi all, can anyone tell me the differences between these 4 frames. When were they made? Thanks!!
    Mar 2012
    I recently purchased a master piu which the seller thought was a late 80s model.It had internal cable routing and 2 bottle cages. I contacted "laura@colnago.com" with the number on the drive side dropout. She requested pictures also.In about 3 days she replied it was a 1999 model.I too would like to know the production years for the different models.
    Jan 2009
    Masters were/are Colnago's top steel frames. The different second parts of the name are just additions at different times. Master Piu was, I thought (despite what Laura at Colnago said) an early model, then Master, Master Olympic for a year or two in the mid-90s then back to Master again. Tecnos was the next steel model down the line from the Master. I've owned a couple of Tecnos and own a Master and there's not much real difference between them although the Master has one more fluted tube and is an ounce or two lighter.
    Oct 2011
    All made in Italy, with Italian steel tubing mostly. Master Extra-light rules. If you can get one and like steel as opposed to carbon, it's the way to go. Have one myself, unbelievable ride.
    Jun 2011
    Thanks c50jim for the information!, I had a Master Olympic and now recently bought a Master Piu. The tubing and the pantographs on the frame looks the same. So it's essentially similar the same but have had a name change. Thanks again for the information.
    Jun 2011
    I currently have a master piu and a mexico, love them.. Just wondering if I should get the master olympic but the tubing and pantographs looks the same as the piu..
    Reputation: Ride-Fly's Avatar
    Mar 2002
    Quote Originally Posted by c50jim View Post
    I thought I read that the Tecnos was actually the lightest steel frame made by Colnago. The Tecnos had a weight limit while the Master series didn't, am I wrong? I assumed that the level of quality and ranking between the Tecnos and Master was equivalent, except for the weight limitation.
    Slightly digressing but what about the Classic? I recall that the Classic was their base model, made of the Cromor-level tubing. Anyone know the ascending hierarchy of Colnago steel frames?
    Ordered and Fitted for my Custom DEAN Titanium frame on Sept 17th, 2008. Finally got it in Oct, 2010!!!
    Aug 2011
    Quote Originally Posted by Rob21559 View Post
    You have 2 great bikes but the Olympic and the Piu are pretty close, both being Masters. Go for a Tecnos and a Super! That would be a sweet quiver of some awesome steel bikes
    Would love to hear some more info on the Tecnos. I recall a source that stated it was the lightest of the steel framed bikes.
    Dr. Frikkenhammer
    Reputation: icsloppl's Avatar
    Aug 2009
    The Master Olympic was only made in 1993, though some have serial numbers placing them in 1994. The Olympic name was dropped after there was some "discussion" of naming infringment with the international olympic committee, making them fairly rare and with a cool story.
    Tecnos up to the 2000 year had a 160lb weight limit. Those after had no limit. They are lighter than Masters and used EL-OS tubing for the earlier ones and "Tecnos 2000" for the later ones IIRC.
    The early ones were well regarded for ride quality but apparently idd not have the descending prowess of the Master series.
    Jun 2011
    Thanks guys for the valuable information, I will keep a lookout for a sweet looking Tecnos since it lighter!👌
    Reputation: boneman's Avatar
    Nov 2001
    Tecnos
    Initial productions years of the Tecnos were made from Columbus EL/OS. It was then shifted to a Columbus drawn DB tube which was called Tecnos 2000. This happened before the year 2000 and continued after 2000. The top tube and down tube were externally ribbed in a x section profile different from the Gilco designed tubes used in the Master et all. I have a 1997 Master Olympic and a late 90's Tecnos made from 2000.
    The so-called weight limit was for the Tecnos made from EL/OS and was something that was done only in the US the the US Colnago distributor which pre-dated Trial Tir. Plenty of people in excess of that weight limited of 170 lbs rode bikes made from EL/OS which at its time was a top tube set.
    I rode my MO as a daily rider for a number of years in Shanghai and while heavy, was the model for stable and confident rides. That being said, my Tecnos was my daily rider for four years in London. Sadly, I did not bring it with me when I moved to Asia. If I had to buy only one steel Colnago, it would be a Tecnos. Oh yeah, I ran Shimano on the Tecnos.
    Attached Thumbnails Attached Thumbnails Master Piu vs Master Olympic vs Master X light vs Tecnos-dscn8507-large-.jpg
    i've got limited minutes left in life, don't waste my time
    Shirtcocker
    Reputation: Bocephus Jones II's Avatar
    Oct 2004
    Quote Originally Posted by Ride-Fly View Post
    You don't buy any of these for being lightweight anyway. Master uses a proprietary tubeset.
    "I regard the brain as a computer which will stop working when its components fail. There is no heaven or afterlife for broken down computers; that is a fairy story for people afraid of the dark." -S. Hawking
    Jun 2011
    Thanks for the information!! Appreciate it very much, cleared certain questions for me. I had a Master Olympic too, bought it around 1995/1996 in Singapore, its Tange tubing though. Later I sold it and bought the Titanio. Regretted selling the MO. I wanted to get a MO for sentimental reasons but The Tecnos is better. But how does the Tecnos compare with Master X Light? Any idea about the present Master that's in production? Thanks buddy!
    Shirtcocker
    Oct 2004
    Master uses the fluted tubing for all tubes in the main triangle...Technos only uses one as I recall. Stays may be different also. Basically the Master will be a stiffer frame which is important if you are an aggressive or heavier rider. Both are great bikes though.
    Nov 2001
    Yeah, those Tange Master's are not that numerous. I would echo BJ II's comments comparing the the Tecnos and the Masterlite. Much of it will also depend on your riding style and weight. Tecnos user population is clearly lower than that of the Master et al but for those who have both, many prefer the Tecnos.
    As I noted earlier, for the Tecnos with Tecnos 2000 tubing, both the top and down tube are ribbed versus all the main tubes on the Master having the Gilco profile.
    Mar 2002
    Quote Originally Posted by Bocephus Jones II View Post
    True Dat!
    Mar 2002
    Quote Originally Posted by boneman View Post
    ....If I had to buy only one steel Colnago, it would be a Tecnos.
    I have an EL OS Mondonico that I feel is the nicest feeling steel I've ever ridden. I'll admit that I am by no means an expert in steel, since my experience is limited to alot of time on Nemo and SL, and a little time on SLX, Brain, Genius, Cromor and a few other lower grades that I can't recall.
    I echo your above statement. IF I could have only one steel Colnago, I'd want a Tecnos in EL OS. BTW, I am 185 lbs. I'm not worried about the limit.
    Reputation: quikrick1's Avatar
    Sep 2011
    Tube Profiles
    Here are some crude cartoon section views showing the basic differences between the Master tubes and the Tecnos tubes. I've never seen the Tecnos EL-OS, so I left it out.
    CORRECTION!! The Tecnos has five creases. Disregard the sketch on the right.
    Attached Thumbnails Attached Thumbnails Master Piu vs Master Olympic vs Master X light vs Tecnos-dsc00567a.jpg   Master Piu vs Master Olympic vs Master X light vs Tecnos-dsc00584.jpg
    Aug 2006
    I currently own several Colnagos.
    A 2007 Extreme Power, a 1993 Elegant, and a 1978 Super.
    I've also owned a Master Olympic, a Master Piu, a Master Extra Light, and several Supers over the last thirty five years.
    Even a 1994 Bititan for a short period of time.
    Loved 'em all for different reasons.
    My favorite steel framed Colnago is my "Wordperfect" Elegant though. EL-OS tubeset!
    I don't recall where it fit in the lineup at the time, but she is a fantastic performer.
    Cool paint in the sun as well.
    Jun 2011
    Thanks guys for all the information. I just bought a Tecnos over eBay, cant wait to get my hands on it.. I will upload the picture as soon as I received it. 👌
    Aug 2006
    Congrats!
    Pics when possible please.
    Singlespeeder
    Jan 2007
    Does anybody here has some information about this stem?
    [QUOTE=Streetking;4012631]Does anybody here has some information about this stem?
    That's made by ITM, with a run designed to mimic the "Master" Profile. I had one on my 1998 C-40. I bought the stem in Italy. They came in different paint schemes, even a fake CF weave. This one to match to blue art decor (or whatever) scheme that was aslo on the Master frames at the time. The pop up frequently on Ebay,
    Singlespeeder
    Jan 2007
    [QUOTE=18usc371;4012769]
    Quote Originally Posted by Streetking View Post
    Thanks....
    May 2009
    So, which tubeset is used in the Master Piu? Not sure it was specifically stated, and I'm looking at a beautiful vintage frame set.
    Also, anyone have an idea how much a vintage Master Piu frameset in excellent condition should cost? It's a stunning fade paint job with lots of chrome. And the geometry is very close to my new Pina.
