Results 1 to 3 of 3
    kma
    kma is offline
    Mar 2005
    Moots Tailgator vs Nashbar rack/pack system
    Anyone have experience/feeback on the Moots Tailgator or Nashbar rack/pack system as a day pack (4+ hour rides to pack food, tools, wet/cold weather gear).
    Nashbar
    http://www.nashbar.com/profile.cfm?c...20Frame%20Bags
    Moots
    http://moots.com/#/product/ti_compon...nal/tailgator/
    Thank you.
    Reputation: Zero Signal's Avatar
    Feb 2008
    Those are pretty sweet. I like that the moots has the dual bags top/bottom, but since it's Moot's it's expensive and way higher quality than what I would want. I might need to pick up one of those Nashbar ones.
    Also pretty nifty with more capacity than the Nashbar one . . . and it has a light mount
    http://www.nashbar.com/profile.cfm?c...20Trunk%20Bags
    Resident Curmudgeon
    Nov 2005
    I've been using a Nashbar trunk rack for a couple of years. I bought the one with the quick release, & I'm glad I did. I have 2 bags, also Nashbar, that I use. One is the largest one they make, and the other is a medium. mostly I use the larger one. The only problem I've had with it was the skewer bolt extends a bit too far from the QR when fastened. It tore a hole in my shorts. I removed it, put it on my bench grinder to shorten & smooth it, and ta-daa. Problem solved. I'd buy it again. They're frequently on sale.
