Page 2 of 2 FirstFirst 12
Results 26 to 37 of 37
  1. #26
    Reputation: SBard1985's Avatar
    May 2012
    That is pure awesome...is it ok if I borrow that at some point?
    Haha, glad you liked it. You may throw around the "green shaft of reputation" anyway you'd like.
  2. #27
    bas
    bas is offline
    Jul 2004
    Quote Originally Posted by PlatyPius View Post
    Completly incorrect.
    a) tubes don't crack.
    b) There have been a lot of tube failures recently due to manufacturing problems - they split or get a hole approximately 1" from the valve. It's a defect unrelated to anything you or a shop has done.
    c) I use 18-23 tubes in my 700x28 tires, and have for years, because they're easier to install.
    After reading this thread, I'm going down this path. 18/23 in 25mm.
    I've had valves go back at the base with 18/23 in 23mm tire. Old age/rot/defects. Who knows.
    Wish me luck.
  3. #28
    Feb 2002
    Quote Originally Posted by bas View Post
    Wish me luck.
    Congratulations! A nearly 4.5 year old thread brought back to life. Not a record for this forum, but definitely near the top.
  4. #29
    Russian Troll Farmer
    Sep 2016
    I don't think we've answers just what presta VALUES are yet......
    "L'enfer, c'est les autres"
  5. #30
    bas
    bas is offline
    Jul 2004
    Tire too big?
    The tire is too big?
    700x25mm (Michelin PR4 Service Course) with 700x23mm michelin tube, mounted on Krysium Sl (~2007) in a Trek Madone 5.2 (2003?)
    Heard the usual stones collecting on the new tire but lots of odd squeaking initially. The stones subsided after the initial tire preserver wore off, but still some odd minor squeaking.
    23mm tube in a 25mm tire? And presta values-dsc05589-sml.jpg23mm tube in a 25mm tire? And presta values-dsc05592-sml.jpg23mm tube in a 25mm tire? And presta values-dsc05595-sml.jpg23mm tube in a 25mm tire? And presta values-dsc05594-sml.jpg
  6. #31
    'brifter' is a lame word.
    Damn, clean your bike. That's filthy.
    I work for some bike racers
    and a bunch of skateboards
  7. #32
    Oct 2013
    Well I'd like to add that schrader valves 'do not' need the little needle pushed down to inflate, if you got pressure in excess, it will blow through the valve regardless of the little nube.
    And I wanted to check out my .... reputation.
    BANNED
  8. #33
    Sep 2016
    I have an older C'Dale, and a 24mm tire just BARELY fits. If I were to try fitting a 25mm tire, it would rub on at least one of my calipers, as well as the cable to the front derailleur.
  9. #34
    Jun 2005
    Quote Originally Posted by B_arrington View Post
    My Presta valve stem snapped off last night and so I had to replace the tube. When I pulled out the spare I realized it was a 23mm, and the tire is 25mm. I put it in anyway and got it up to the right pressure (115 lbs - I'm a big dude).
    What's the impact - if any - on using a smaller tube in a larger tire? Is there any reason to think the tube is going to have a shorter life expectancy? Should I swap it out for a 25mm tube right away, or just leave it alone?
    And about those Presta values - other than being more Euro and "pro" looking, do they have any function advantage over a Schraeder valve? I've always found them more finicky to use and they feel more delicate. I've worried about them breaking, and then it happened last night.
    Jeebus. Tubes are not that size specific. If you take one out of the box and pump air into it, you will notice that it swells up quite a bit.
  10. #35
    Feb 2013
    The 18/23 tube is probably the same as a 23/25 "ultralight" tube, only a couple of bucks less.... Also easier to get on than a 23/25, so less likely to pinch it when you're rushing on the side of the road...
  11. #36
    Reputation: JCavilia's Avatar
    Sep 2005
    Quote Originally Posted by arshak View Post
    Exactly. Just as the very first response to the thread said 4 1/2 years ago, and half a dozen others repeated.
    Have you ever been to Electric Ladyland?
  12. #37
    Jun 2005
    Quote Originally Posted by JCavilia View Post
    Whoops! My bad. Did not know I was replying to a Paleolithic era thread.
  1. 23mm tire on 25mm rim
    By by666 in forum Wheels and Tires
    Last Post: 08-01-2013, 07:04 PM
  2. 23mm tire on 25mm wheel?
    By gravitywell in forum Wheels and Tires
    Last Post: 09-15-2012, 07:02 PM
  3. Replies: 11
    Last Post: 09-15-2012, 11:28 AM
  4. safe to use 700x18/20c tube in a 23mm or 25mm tire?
    By czacharyasz in forum Beginner's Corner
    Last Post: 01-17-2010, 09:25 AM
  5. 25mm tire/18-23mm tube?
    By thenazz in forum General Cycling Discussion
    Last Post: 04-21-2006, 06:19 PM
