Results 1 to 12 of 12
    Apr 2002
    25mm to 28mm Tire
    I want to change from 25mm tires to 28mm. There is plenty of room in the fork. The question is the back. Presently I have a 25mm Continental Ultra Sport tire. I measured the clearance to the brake. It is about 9mm. Will a 28 mm tire fit?
    Thanks in advance
    Jun 2004
    Quote Originally Posted by daniell View Post
    Thanks in advance
    Only way to know is to try mounting the 28mm tire. Tire sizes vary among the manufacturers, thus only way to know what fits is to buy it and try it.
    Also watch the clearance at the chainstays.
    Apr 2002
    Quote Originally Posted by Steve B. View Post
    Plenty of room at the chainstays.
    Reputation: Lombard's Avatar
    May 2014
    Brakes can usually be adjusted. It's mainly the chain stays that are the limiting factor. If there is room there, then go for it!
    -- Warren Buffett
    Apr 2002
    I am referring to the top of the tire hitting the bottom of the brake.
    Reputation: velodog's Avatar
    Sep 2007
    What does your 25mm tire measure out to? On paper you will have 6mm clearance with the 28mm tire, so it should fit but you won't know till you try. But if you've got the room at the chainstays hopefully the manufacturer gave the frame matching clearance at the brake bridge.
    Too old to ride plastic
    Yes. Assuming you are not comparing two different tires or tire brands that use a completely different measurement standard, 9mm is plenty of room to move up 3mm in tires size.
    Nov 2014
    Exactly. Most 28mm tires are really more like a smidge over 27 anyway. And, a just few are closer to 30....
    May 2014
    Quote Originally Posted by harryman View Post
    That all depends on the rim you are mounting it on. A tire that measures 28mm on a 15mm ID rim will measure 29mm on a 17mm ID rim.
    -- Warren Buffett
    Apr 2002
    I will be using a Mavic Open Sport rim. My only concern is the height. I have ample side room. Another concern is whether I will be able to get an inflated tire through the brake blocks. These are Ultegra brakes.
    It shouldn't be. There will be plenty of room, with the brakes released. And is letting air out of a tire really a problem? (moot question because you won't need to do that.)
    Oct 2013
    Just borrow a 28 and try it.
    BANNED
  1. Any reason not to go with 28mm tires over 25mm?
    By Peter2290 in forum Wheels and Tires
    Last Post: 04-03-2017, 10:59 AM
  2. 23mm tire on 25mm mm rim or 25mm tires on 20.5 rims - questions
    By littlepitboy in forum Wheels and Tires
    Last Post: 01-09-2017, 05:37 AM
  3. Any issues running an 18-25mm tube in a 28mm tire?
    By lacofdfireman in forum Wheels and Tires
    Last Post: 11-22-2016, 05:37 AM
  4. hongfu fm069 + 25mm wide carbon wheels + 25mm gp4000s?
    By hernluis in forum Bikes, Frames and Forks
    Last Post: 05-05-2015, 10:23 AM
  5. Colored 25mm-28mm tires
    By wily in pacifica in forum General Cycling Discussion
    Last Post: 02-09-2004, 05:14 PM
