Results 1 to 7 of 7
    Apr 2002
    3T ARX bolt replacement
    I am in nedd of one 3T ARX stainless steel stem bolt.
    All I have found so far is the titanium version which I don't need or want to pay $20 + dollars for.
    Anyone know where I can find some?
    Thanks in advance!
    'brifter' is a lame word.
    oddly enough i'd try a bike shop...they usually have things like that just laying around. go figure...
    2010 Cervelo T1 sprint bike
    Ruger 10-22TD
    Smith&Wesson M&P 15-22
    Smith&Wesson M&P 9
    oh, those belong in another forum
    Apr 2002
    hey cx..
    oddly enough it’s a special bolt – the LBS broke it and put on a replacement that looks like…..
    Still On Steel
    Reputation: Allez Rouge's Avatar
    Dec 1969
    Hmm, semi-proprietary fasteners can be tough, because components typically come with Just Enough And No Extras. Two suggestions:
    1. Try the special fasteners cabinets in the hardware aisle at Lowe's or Home Depot. A long shot, but you might get lucky and the price will be reasonable.
    2. Replace both (stem clamp) or all four (face plate) with bolts that match each other.
    Allez Rouge
    Reputation: looigi's Avatar
    Nov 2010
    Quote Originally Posted by dasho View Post
    The bike shop should have at least replaced all four with a matching set scavenged from an old/cheap stem they have lying around or off a used bike.
    it's a stem bolt...how special can it be? if they sell those stems or have bikes that they come OEM on i'll bet they have some bolts that will work. i know we do...
    Ruger 10-22TD
    Smith&Wesson M&P 9
    Oct 2009
    It's an M5 x 15 tapered socket head cap screw. Commonly available, sometimes used as bottle cage bolts.
    The ones on my ARX stem are chrome plated steel.
  1. Broken bolt in brake cable bolt assembly
    By ronniedee in forum Components, Wrenching
    Last Post: 10-02-2010, 05:56 PM
  2. Difference between 2-bolt and 4-bolt stems
    By rkdvsm in forum Components, Wrenching
    Last Post: 01-28-2007, 05:29 PM
  3. Tightening specs for 4-bolt and 2-bolt stem ?
    By Pierre in forum Components, Wrenching
    Last Post: 02-26-2006, 03:56 AM
  4. 4 Bolt stem on "only 2 bolt h-bar"
    By breggurns in forum Components, Wrenching
    Last Post: 10-02-2005, 11:28 AM
  5. Two-bolt or four-bolt stems?
    By Wisbiker in forum Components, Wrenching
    Last Post: 12-21-2004, 07:47 AM
Sea Otter Classic
Contest
