Results 1 to 4 of 4
    fu
    Reputation: ph0enix's Avatar
    Aug 2009
    3T Palladio seatpost
    Have you used it? If so, what's your impression?
    Feb 2006
    Never used it but there is an issue with the clamp only supporting 7mm round rails:
    http://weightweenies.starbike.com/fo...hilit=Palladio
    So you should measure whatever the rails on the saddle you are planning on using to make sure the rails will fit into the clamp.
    fu
    Aug 2009
    Thanks! Good to know. I guess no saddles with carbon rails on that puppy. That's a deterrent!
    Feb 2010
    nice!
