Results 1 to 12 of 12
    May 2013
    52/36 On 110 FSA Crank?
    So I purchased a leftover 2012 CAAD10-3 this week on a great deal that I couldn't pass up, and at the time, didn't really know much of anything about gearing, what a compact vs. standard was, or any of that. I took the bike out for a short spin and quickly learned this was a compact, as I spun through the 34 ring effortlessly and could push most of the cogs with the 50 ring. This was a flat road into a headwind, I should mention. I've been previously riding a bike with a triple and could push the center ring (a 42) up most hills, so needless to say, I could spin that little 34 ring up the walls of my house.
    As it turns out, the LBS had swapped the std 53/39 set off the bike for another customer during the months that it sat in the shop and put the compact on it, and unfortunately, I really didn't know any better until I really rode it a decent distance.
    The LBS offered to put a set a 52/36 FSA rings on it that they have, but after a long night of research and studying up on gearing, it seems this may not work well. The crank on it is the stock FSA SLK light carbon 110. I feel as though the 52/36 would really offer the best of both worlds, but many comments I found during my research said it doesn't work due to flex.
    What would be my best option, aside from plunking down several hundred for a new crankset? I could put an 11-25 cog on it as many seem to do, but I don't see that as an all-encompassing solution. Thoughts?
    'brifter' is a lame word.
    Quote Originally Posted by AW84 View Post
    i'd try the cassette first. there are plenty of pro women racing on compact and i'm pretty sure they're a bit faster than you. the only thing that will come close to feeling like your 42 middle would be a 39 on a standard. you may find that is what you really want in the end. the difference between 52 or 53 on your triple and the 50 on the compact is actually pretty small, the big difference is between the 42 and the 34. you can easily pedal a 50/11 to over 40mph...it's actually a bigger gear than what you had on your triple, i'm betting. if you had 53/12, the 50/11 is a larger gear.
    I work for some bike racers
    and a bunch of skateboards
    May 2013
    I checked back with the LBS and what they have is a 52/38 FSA cassette set. They informed me that they've put that combination on a few bikes, including a SuperSix that belongs to one of the salesman. If it does work, I think that'd provide the best of both worlds for at least a year or two until I decide to switch out to a standard. The triple that I rode was a Shimano 105 52-42-30, and I could ride all day without ever moving out of the center ring. I'd jump to the 52 to fly down steep descents (basically about 2% of my total riding), but otherwise, the 42 was all I needed for the flats and rolling terrain.
    I live in Indiana, where you're not riding mountains, but it's not flat either, so a decent mix of downhill gear and some climbing gear would be perfect.
    Reputation: SBard1985's Avatar
    May 2012
    Don't look at is forking over hundreds of dollars. Sell your crank on ebay, and buy another takeoff from somebody on ebay. You may even make a few bucks too. It's your bike, I say you need it to be equipped the way you want it. If you want a 130 BCD crank, then go get yourself that crank.
    May 2013
    I suppose for resale value a standard with a 130 BCD crank would be good, but i don't particularly need it. Even hauling the mail down hills, I never once used 52-12 on the bike with the triple. I don't know that I ever even got into the last couple of cogs on downhills. So on a standard, I'd certainly never use the high end of it (the 53-12) so the 52/38 setup seems like the sweet spot.
    Jun 2010
    just swap the 34 for a 36t chainring. Shouldn't cost more than $30
    Reputation: JCavilia's Avatar
    Sep 2005
    You're getting hung up on terminology, and confused by it.
    52/38 essentially IS a "standard." "Standard" cranksets generally have a 39 and a 52 or 53. That's damn close to what you'd be getting. The only difference with a "standard" is that you'd have those rings on a 130mm bcd spider, rather than the 110, and that don't make no difference -- that "flex" business is mostly myth.
    You say you'd "never" use 53x12. That really means the 50x12 you have now is high enough. So why do you want to buy a 52 ring? If you'd like to stay in the little ring more, and you find the 34 a little low, put the 38 on there.
    You never said what cassette you have -- there are options there, too.
    We are far from pefect,
    But perfect as we are
    We are bruised, we are broken,
    But we are goddamn works of art
    Works of art
    May 2012
    I have a 52-36 Campy on a bike and I have a 52 - 36 FSA crankset on another bike.
    My preferred crankset and the notion that the average person is going to feel "flex" is utter nonsense.
    Feb 2013
    I have 52/36 SRAM rings on an FSA SLK cranks and it works perfectly on a 10 speed Ultegra setup. Ive also run 50/34 FSA rings (which came on the bike) and 53/39 Aerozine rings without a problem. Using a 11-25T cassette out back.
    Cranky Old Bastard
    Reputation: Randy99CL's Avatar
    Mar 2013
    It's crazy that people are talking about selling that crankset and buying another (for hundreds of $$$).
    Forget the compact/standard labels; just get rings that will work for you.
    What cassette were you running with the triple? If you want to match your old gearing you need to figure out what you had in gear/inches and duplicate that.
    "When you know absolutely nothing, anyone who knows 1% more than nothing sounds like an expert."
    Apr 2012
    The Praxis Works 52/36 for a 110 is their most popular chainring set. Cold forged. Nice stiff and crisp shifts...Praxis Works | Road Rings
    Jun 2007
    Maybe I'm missing something, but I don't understand why you're not happy with the 50t large chainring you currently have.
    You said you never need a 53-12. You can cheaply and easily find a cassette with an 11t small sprocket. Using that sort of cassette, and your 50t compact crank chainring .... 50-11 is a higher gear than a 53-12, so if you never need that 53-12, you'll have plenty of high gears with the 50t. In fact, if you never use the 53-12, a 50-12 is only a tiny bit lower, therefore from what you wrote, the current crank should be fine in the high end without replacing the 50 with a 52 or changing to to a conventional crank. Correct me if I'm misunderstanding.
    SO - just change the 34t small chainring to something that suits you better, like a 42 or 40 or 39, or whatever. They're readily available in the 110 BCD. For example: T.A. Specialites Zephyr 110 BCD Road Chainring (Middle/Inner Position) - Harris Cyclery bicycle shop - West Newton, Massachusetts
  1. shimano 600 crank / gears with old square BB vs using BB30 crank
    By SinnerDC2 in forum Components, Wrenching
    Last Post: 12-15-2010, 09:07 PM
  2. Campy Compact Crank Q- swap out crank arm?
    By dockay in forum Components, Wrenching
    Last Post: 05-04-2009, 08:28 PM
  3. Do I need a Crank Puller for a Shimano 7700 crank?
    By Uprwstsdr in forum Components, Wrenching
    Last Post: 07-24-2008, 09:36 AM
  4. Cannondale Si crank vs. Campy Record crank
    By zamboni in forum Cannondale
    Last Post: 04-22-2008, 05:26 PM
  5. Compact Crank vs. Regular Double Crank?
    By duke26 in forum Components, Wrenching
    Last Post: 12-17-2005, 09:38 PM
