Results 1 to 7 of 7
    Reputation: Ajost's Avatar
    May 2012
    6, 10, or 17 degres stem
    I need a new stem. Been using a 6 degree.
    Between the three: 6, 10, 17, should I try them all or just stay with the 6 degree?
    Any advice would be appreciated on the pros and cons of each stem degree
    v/r
    Ajost
    2012 Cannondale Supersix 105
    What the what???
    Jul 2009
    Is there a fit/comfort issue you're having with your current stem? If not, I think I'd stay with the 6 degree.
    Nothing in all the world is more dangerous than sincere ignorance and conscientious stupidity. - MLK
    Lost in Space...
    Reputation: headloss's Avatar
    Mar 2013
    If you have to ask, then you shouldn't change it. It's really a combination of rider position, frame size and geometry, intended use of bicycle, any physical discomfort, handlebar type, shifter type, and on and on and on that determine if you need a different stem.
    Hucken The Fard Up !
    Reputation: Salsa_Lover's Avatar
    Jul 2008
    I use a -17 only because it is aligned with my horizontal top tube.
    If it was sloping I would use a -6
    That is if the frame is properly sized btw
    Quote Originally Posted by zank
    They're just bikes. Ride 'em in the rain, salt, snow and crap to fully appreciate them.
    Quote Originally Posted by Sean Kelly
    The thing about the cold is that you can never tell how cold it is from looking out a kitchen window. You have to dress up, get out training and when you come back, you then know how cold it is.
    Burnum Upus Quadricepus
    Reputation: brucew's Avatar
    Jun 2006
    It depends on where you want the bars to be. The only pros or cons to stem angle are does it put the bars where you want them? (Other than those who have an aesthetic preference, of course.)
    Stem Chart is a visual stem calculator. Put in what you have now in one, and use the second to figure out where you want the bars to be, or where the second stem will put the bars.
    The default when you first visit the site shows two ways to get the bars to the same place.
    Reputation: looigi's Avatar
    Nov 2010
    Quote Originally Posted by brucew View Post
    It depends on where you want the bars to be. The only pros or cons to stem angle are does it put the bars where you want them? (Other than those who have an aesthetic preference, of course.)...
    Exactly. Proper fit and preference determines where the bars need to go with respect to the saddle in reach and height. The angle and length of the stem along with the height of any spacers under it are what physically mounts the bars in the desired position. Within limits, you can trade of spacers with stem angle.
    ... 'cuz that's how I roll.
    pmt
    pmt is offline
    Aug 2009
    You should probably just stop right now and make an appt with the LBS for a proper Retul or Guru fitting. It's well worth it.
  1. Replies: 12
    Last Post: 09-03-2011, 08:28 AM
  2. Replies: 11
    Last Post: 12-14-2010, 08:42 AM
  3. Effect of stem spacers and stem length on handling
    By il sogno in forum Bikes, Frames and Forks
    Last Post: 08-15-2008, 05:42 AM
  4. stem angle vs stem length vs bar height geomtery question
    By acid_rider in forum Bikes, Frames and Forks
    Last Post: 05-11-2007, 04:33 AM
  5. Quill stem, stem adapter, oversize bar?????
    By Fattybiker in forum Components, Wrenching
    Last Post: 03-04-2006, 08:10 PM
