Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
  1. #26
    Jul 2017
    Quote Originally Posted by pmf View Post
    You're going to need new wheels. Or at least a new rear one.
    See JCavilia comment below.
    Quote Originally Posted by JCavilia View Post
    He said that he's been running an 8-9-10-speed hub on it for 10 years, springing it open when installing the wheel, with no problems. I think he's got that part covered, and he doesn't need a new wheel.
    Yes.
    Quote Originally Posted by fast ferd View Post
    edit: I took a quick spin on a 2100 years ago and it rides exceptionally.
    I recommend buying a complete 5800 (105 11-sp) groupset.
    Online prices delivered below $375 new. Very nice shifting and braking.
    You can likely recover a fair chunk of change selling your old stuff on eBay.
    I was surprised to see the 105 11 speed shifters are actually cheaper than the 105 10 speed ones.
    Maybe I should have looked into this option more but the thought of a new rear wheel and/or rear hub conversion scared me off.
    And I've now pulled the trigger on all the 10 speed gear with the exception of the cassette.
    Below is the full part / price list. Price might go up or down $5 or so depending on a few eBay auctions I'm waiting to end but at this point it's pretty set.
    Thanks to all for advice and input!
    Will update thread with pics once everything arrives in the mail and I've had a chance to install the gear.
    Attachment 319679
    Attached Thumbnails Attached Thumbnails 7spd Downtube to 10spd STI Conversion-10-speed-conversion-screenshot.png
  2. #27
    Reputation: Lombard's Avatar
    May 2014
    Tjc4,
    That looks really cheap for a cable and housing set. Check to make sure these are stainless steel cables. Many cheaper cable sets are galvanized. Galvanized cables will oxidize causing them to become rough. Rough cables can bind inside the housings causing poor shifting.
    This is not a place where you want to go cheap. You can have the highest end components in the world and if your cables are crappy, your shifting will be crappy.
  3. #28
    Jul 2017
    Tjc4,
    I ordered what was listed as Shimano "Stainless Steel PTFE coated cables" with "4mm SIS-SP41 housing." link
    But this is what I received.
    I now note it does not have the PTFE cable icon, it only lists the housing as SIS (not SP41), and I see some of the Amazon reviewers state they also got the cheaper stuff
    Thanks for pointing that out. I otherwise probably wouldn't have noticed. Sounds like I should return this and get some better stuff.
    Edit / Update: just ordered what appears to be some authentic PTFE cable / SP-41 housing off ebay for $22.
  4. #29
    May 2014
    PTFE is not as big an issue as stainless steel. Stainless steel is a gotta have. Yep, return it and get the good stuff which will usually cost $20-25.
  1. Front derailleur compatibility (7spd to 10spd)
    By drdiaboloco in forum Components, Wrenching
    Last Post: 04-30-2010, 11:08 AM
  2. Downtube to STI conversion
    By EBrider in forum Components, Wrenching
    Last Post: 11-05-2009, 10:42 AM
  3. Downtube to STI Conversion
    By moff_quigley in forum Retro-Classic
    Last Post: 09-07-2006, 10:39 AM
  4. 7spd to 9spd conversion
    By abqbiker in forum Components, Wrenching
    Last Post: 01-03-2005, 10:53 PM
  5. STI levers work with 7spd?
    By split in forum Components, Wrenching
    Last Post: 04-02-2004, 06:21 PM
