Results 1 to 25 of 25
    Cleavage Of The Tetons
    Feb 2005
    anyone have a few KMC 11 speed chain links to spare?
    Just looking for two or three.
    I could PP a bit for shipping!
    'brifter' is a lame word.
    Quote Originally Posted by rideit View Post
    How is this easier than just going to Amazon or something and just ordering some?
    I work for some bike racers
    and a bunch of skateboards
    Feb 2005
    I don't think you can order two or three links.
    I already ordered the masterlink...this seems like something people would have in their tool kit from when they cut their chain to size.
    You don't have a few, do you?
    Ohhhhhh...just plain chain links? No, I always throw away the extra links when I cut a chain.
    Sep 2011
    damn I just threw away about 4 links when I cut my 11 spd chain. Hopefully someone will have a few to give you! Also, check your LBS if there's one close by. My LBS mech is cool he has given me small things like washers and hex and spacers for free.
    Russian Troll Farmer
    Sep 2016
    Sounds like somebody got a new larger cassette, but wants to use the old, shorter chain with 2 master links and a short section between them.
    "L'enfer, c'est les autres"
    Feb 2005
    Bingo, Sherlock! ;-)
    Sep 2016
    Well, master links are usually the most likely thing to fail on a chain, and you want to ride with 2 of them? What you'll end up with is about a 5" long section that just won't catch the shifting ramps like the rest of the chain, and all the shifting degradation that goes along with it.
    Just buy a new chain, and store the old one with the old cassette.
    a real member's member
    Jul 2016
    try ebay. and find a new 11-speed chain (sram or kmc) sold without its packaging. should be inexpensive.
    Reputation: Lombard's Avatar
    May 2014
    If you are installing a new cassette and your exisiting chain has more than 1000 miles on it, replace the chain! A worn chain will wear out your nice new cassette very quickly.
    Feb 2005
    Chain has 5 rides on it.
    May 2014
    Well then, buy a spare chain and use the extra links you need. Simple.
    Apr 2014
    I don't have any spare links to spare...not a link. But I have done what you are proposing & it works no problem & has been reliable for 2 seasons now. It shifts the same as a normal setup. As for chain failures, I've had chains fail but it was never a quick link that failed on me in the over 20yrs of riding ymmv.
    Instead of 2 quick links, you could always use 1 with a connector pin instead if ypu're worried. Try posting this on the bulletin boards of the local clubs in your area. Extra links & pins are things that most people just throw away after they cut & connect their chain with a quick link.
    Reputation: Srode's Avatar
    Aug 2012
    Simpler would be to buy a spare chain, put it on the bike and save the one you take off for later.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    May 2014
    Or this.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    This ^^
    Chains don't spoil. Unless you plan on selling your bike in the near future, you're going to need a new chain eventually.
    I always have at least 1 spare chain on hand.
    May 2014
    This ^^
    ^^That^^
    Chains don't spoil.
    Wouldn't hurt to store it in the fridge, just in case
    May 2014
    Quote Originally Posted by DaveG View Post
    But not the freezer. Frost will kill the chain.
    Apr 2014
    Wouldn't putting a chain in the freezer reverse chain stretch??? Can you say shrinkage!!
    And yes I agree with everyone above. Buy a new chain but make sure its a full length one at 116 links long & not some oem chain that has been shortened.
    tlg
    tlg is online now
    May 2011
    Like how the Titanic sunk from brittle fracture caused by freezing water.
    May 2014
    Quote Originally Posted by stan01 View Post
    No, no! It actually expands when it goes through the freezing process like ice does. Don't do it, you'll ruin the chain!
    I think we can start a new, never-ending debate here: freezing vs heating your chain
    Feb 2005
    So, I have run the extra links and materlink for a few hundred miles, including a 5000ft climbing day.
    Performs flawlessly.
    But this comes as no surprise, as I once ran a mt. Bike chain with three master links for a trip in Peru that had ungodly amounts of climbing.
    So that's my update.
    However, I only ride in sub-zero temperatures so my chain doesn't smell funky.
    tlg
    tlg is online now
    May 2011
    Similar to heat treatment, there's cryo treatment.
    https://en.wikipedia.org/wiki/Cryogenic_treatment
  1. Links, links and more links
    By tihsepa in forum The Lounge
    Last Post: 11-28-2013, 05:20 PM
  2. Chains...LBS spliced a few shimano links into a KMC. Ok?
    By sqwk77 in forum Components, Wrenching
    Last Post: 12-24-2011, 12:15 PM
  3. KMC 11SL chain and KMC Missing Link?
    By ejr13 in forum Campagnolo
    Last Post: 01-17-2011, 12:25 AM
  4. Using KMC links w/ Dura Ace chain...ok idea?
    By pbird74 in forum Components, Wrenching
    Last Post: 03-04-2010, 07:28 PM
  5. 96 Links of chain on by bike, 96 links of chain..
    By hrv in forum Fixed/Single Speed
    Last Post: 03-22-2004, 08:44 AM
