Results 1 to 11 of 11
    mad11:11one
    Reputation: MANTEIGA's Avatar
    Sep 2008
    Anyone Madone owners out there using the adapter on their workstands?
    Just got one today.
    i also own a clamp style repair stand with integrated pads.
    My understanding by looking at it is that i simply need to rotate
    my workstand's horizontal clamp 90 degrees so that the thing is clamping
    downwards, (parallel to the floor) then clamp the adapter in the same direction... in other words,
    just turn the clamp from vertically holding the seatpost itself, to horizontal
    holding the adapter which in turn is holding the vertical seat post......!?
    sorry. even i got dizzy writting that.....
    there is crap instructions from bontrager, and no pics on the net...
    anyone got one of these things with a bontrager pro wrench stand?
    i hate experimenting with my bike when im not 100%...
    Sep 2007
    seatpost?
    ahhhhh, .....you can't use the seatpost on the new Madones can you..... I was about to make a really stupid suggestion, weird that I stopped myself in time
    mad11:11one
    Sep 2008
    Quote Originally Posted by martinrjensen
    huh??
    Reputation: 08Madone5.2's Avatar
    Dec 2007
    You open the adapter up, clamp it around the seatcap/mast, close the adapter, secure the end of the handle with the band provided, then clamp the handle into your work station clamp
    mad11:11one
    Sep 2008
    Quote Originally Posted by 08Madone5.2
    what, did you write the instructions for bontrager!?
    im not an idiot.
    i was referring to the angle of my existing stand.
    but thanks.
    Sep 2007
    explanation
    Quote Originally Posted by MANTEIGA
    huh??
    The 08's have that new special seat mast that wouldn't fit in a clamp very well, at least I wouldn't think so. I have a 07 and I just use my seat post for the clamping sufface.
    Sep 2007
    [QUOTE=
    but thanks.[/QUOTE]
    Your clamp rotates doesn't it?
    mad11:11one
    Sep 2008
    wow....
    i'm pretty dumb.
    sorry,....
    i guess there is only one logical way to do this......
    i just got home with the part and figured it out...
    (my pro wrench stand has an integrated pre-loading device that allows
    you to mount bikes with one hand,,....
    rotating the mount 90 degrees makes the device usable as a quick
    hanger, but does not aid in mounting the bike to the stand, which was it's purpose......?!
    this is what confused me.....)
    whatever....
    thanks for all of you that replied.
    i'll be ok.
    Sep 2007
    pic?
    i'm pretty dumb.
    sorry,....
    whatever....
    i'll be ok.
    Humm......I can't see that in my mind...a pictures worth a thousand words.
    mad11:11one
    Sep 2008
    here you go
    clamp is clamping adapter.
    everything looks normal, except the bontrager hanger thing becomes disabled with a 90degree rotate
    Sep 2007
    views.
    hummmm....I will have to go look at one of those at the bike shop. seems like it's looking like the (Bontrager repair stand) has a design deficiency? So by mounting with one hand you mean you can hold the bike up in the clamp and then just close the clamp lever and it exerts the correct amount of force on the item, but it doesn't work this way if you rotate the clamp angle 90 degrees?
