Results 1 to 8 of 8
    What the what???
    Jul 2009
    Apex 1 rear derailleur wobble
    I'm new to 1X... heck, I'm new to 11sp... so apologies in advance if this is "normal". I attempted to find the SRAM manual for this but had no joy.
    I have an 11sp, SRAM Apex 1 rear derailleur. With the derailleur de-tensioned (shifted to the small cog, and with the chain off the bike), the derailleur has a fair amount of wobble/play (inboard and outboard). It feels loose. But the bolt attaching it to the hanger is good and tight and the hanger itself is tight to the frame.
    Is this wobble/play built in to provide some flexibility to aid in shifting since it's a 1X system?
    If not, any ideas what the proper torque should be for the derailleur bolt attaching to the hanger?
    The Law of Headwinds states: If the ride out is easy, you better have something saved for the turn...
    'brifter' is a lame word.
    Normal. SRAM recommends 5-7nm. There user manuals and service manuals are very easy to find on their site. Service tab right at the top. Grease the threads when you install it.
    I work for some bike racers
    and a bunch of skateboards
    What the what???
    Jul 2009
    Yeah. Their site has diagrams, but I couldn't find anything for installation or adjustments on the Apex 1X to tell me if the inboard/outboard play was normal.
    So, it's by design?
    There is nothing about the movement. It just happens. The torque for the attachment bolt is clearly shown as is the need to grease it so you get the proper torque. Don't overthink this.
    wim
    wim is offline
    Feb 2005
    Agree with cxwrench, it's normal. There has to be some play in that pivot to guarantee free movement of the derailleur no matter how tight the mounting bolt. The play becomes negligible when putting tension into the coil spring housed in that pivot and when the derailleur cage with the chain in it can stabilize the derailleur. Putting the chain back on your bike will do all that.
    What the what???
    Jul 2009
    Thanks to you both. I'll resist the "fix it till it's broken" part of me that wanted to throw a washer in there, and I'll leave it as-is.
    Quote Originally Posted by Opus51569 View Post
    You should never attempt to out-engineer Shimano, SRAM, or Campy. They pretty much know what they're doing.
    What the what???
    Jul 2009
    I didn't think it was poor engineering, just maybe a QC issue.
  1. wobble in DA 7850 rear hub
    By steelbikerider in forum Components, Wrenching
    Last Post: 01-15-2016, 06:52 AM
  2. Rear Derailleur (Apex) Barrel Adjuster Question
    By RaptorTC in forum Components, Wrenching
    Last Post: 05-31-2013, 06:10 PM
  3. SRAM Apex Rear Derailleur issues on CX bike
    By drussell in forum Cyclocross
    Last Post: 05-06-2013, 12:46 PM
  4. SRAM Apex Rear Derailleur: Low Limit Screw Affecting High Limit
    By quasi888 in forum Components, Wrenching
    Last Post: 06-29-2011, 06:18 AM
  5. Replies: 8
    Last Post: 06-07-2011, 04:12 AM
