Results 1 to 9 of 9
    Reputation: boleiro's Avatar
    Jun 2010
    BB Cable Guide Help...
    got a new frame to build up, just waiting on delivery for Potenza groupset. The cable guides on the BB are pretty minimal compared to cable guides on my previous frames. I'll definitely get cable rub, will this affect shifting performance? The guides are too small to fit shift cable housing. BB Cable Guide Help...-bottom-bracket-small.jpgClick image for larger version.
Name:	Bottom Bracket small.jpg
ID:	318780Will it be worth it to put some kind of tubing to reduce friction or should I just cable it up and ride?
    Any advice and tips from your experience is appreciated!
    "When everybody thinks alike, nobody is thinking."
    'brifter' is a lame word.
    Quote Originally Posted by boleiro View Post
    got a new frame to build up, just waiting on delivery for Potenza groupset. The cable guides on the BB are pretty minimal compared to cable guides on my previous frames. I'll definitely get cable rub, will this affect shifting performance? The guides are too small to fit shift cable housing. Click image for larger version.
ID:	318780Click image for larger version.
    I'd probably try some liner through those guides and see how it works. They might slide a bit, especially on the front derailleur cable, but you can just move it back every now and then.
    I work for some bike racers
    and a bunch of skateboards
    Jun 2010
    as in liner from normal shift cables? I have extra cable lengths, I'll give it shot.
    thanks!
    a real member's member
    Jul 2016
    to use liner or not ... it probably doesn't matter.
    i wouldn't. others would. some that don't will mention the ability for moisture to collect in the liner.
    Jun 2010
    That was one of my main questions... would tubing or anything really affect the shifting performance. If not, I'll probably go as is.
    Jan 2010
    Don't do anything. It will be fine.
    Here is a pic of another old, wonderful shifting, bike's BB area
    There's sometimes a buggy.
    One.
    Jun 2010
    that's more of what I've worked with in the past... but I guess it's still just steel it's rubbing on.
    thanks guys!
    Feb 2005
    If I recall, didn't some older frames use some stainless housing without the vinyl coating to guide the cable around the BB area. Same as what they used for bar ends on vintage road bike.
    Apr 2014
    I built up something similar to yours & I agree with CX about the liners. I bought some Ashima Reaction cables that came with full length liners & grubs. So I just ran some long sections of liners all the way to the derailleur bolts. Shifts great. BTW I hope you post some pics when you have it built, I'm liking that paint job a lot.
  1. Replies: 2
    Last Post: 06-06-2013, 04:35 AM
  2. BB cable guide
    By nayr497 in forum Components, Wrenching
    Last Post: 09-29-2012, 09:08 AM
  3. cable guide
    By merckx72 in forum Jamis
    Last Post: 11-22-2010, 09:03 PM
  4. BB cable guide
    By arinowner in forum Components, Wrenching
    Last Post: 02-21-2010, 10:01 AM
  5. BB cable guide for VXR?
    By C40 in forum Other Builders
    Last Post: 09-19-2006, 07:54 PM
