Results 1 to 4 of 4
    Sep 2012
    BB30A and BBright?
    Could someone with some experience with these two configurations help me out? I just bought a Synapse with BB30A, and I'm looking for a solution to run Shimano cranks without adaptors (24mm spindle). WheelsMFG makes a threaded BBright bracket that accepts a 24mm spindle. They do not however make a BB30A bracket.
    It's my understanding the only difference between the two is BBright is 79mm wide, while BB30A is 73mm wide. Seems to me the only thing preventing this BBright from mounting into a BB30A frame would be the threads bottoming out. If it has enough thread to 'take-up' the extra 6mm, would this work?
    BBRight? Outboard ABEC-3 BB for 24mm (Shimano) Cranks - Black
    Jan 2010
    BBright is pressfit 30, ie 46 mm dia.
    BB30a is a wider version of BB30 with a 42 mm ID.
    So no, it won't work because 46 mm dia won't fit into 42 mm dia.
    There's sometimes a buggy.
    One.
    Sep 2012
    Quote Originally Posted by bikerjulio View Post
    I must have been reading wrong info....thanks.
    Jan 2010
    Wheels have adapters. They plug into the installed bearings to sleeve them down to 24 mm. Then a variety of spacers as required.
    So you need to have the BB30 bearings installed first.
    BBright, BB30a & PF30a Adapter for 24mm Spindle Cranks (Shimano, FSA, etc.)
    One.
  1. BB30A to 24 mm on a CAAD12
    By SFTifoso in forum Components, Wrenching
    Last Post: 08-21-2016, 12:42 PM
  2. BB30a crankset question
    By Slice Ryder in forum Cannondale
    Last Post: 08-07-2016, 03:49 AM
  3. bb30a crankset compatibility
    By notwist in forum Components, Wrenching
    Last Post: 03-07-2016, 08:26 PM
  4. BB30A with Campy?
    By boomersooner69 in forum Cannondale
    Last Post: 04-07-2015, 08:28 PM
  5. Bb30a ???
    By wayne in forum Cannondale
    Last Post: 12-05-2014, 06:55 AM
