Results 1 to 5 of 5
    Apr 2014
    BB7 Road - Noise Issues
    Hey All.
    I got a Fairdale Weekender about a month ago and I really like it. It came with Avid BB7 Road disc brakes, which I was stoked about because I have the BB7s on my MTB and they work really well, are simple to set up, and don't make noise.
    I have not had the same experience with the brakes on my Weekender. While the stopping power is great, they make a ton of noise. I have taken the bike back to the shop 3 times to have the problem sorted and they have not fixed the issue. I could keep taking it back, but I'd rather just get the problem fixed.
    First, the noise. I get some squealing, but I mostly get a grinding type noise.
    I took the pads out of the calipers and they have strange wear marks on them. It looks as if the pad is bigger than the braking surface on the rotor and that the outer edge of the rotor is wearing a line into the pads. I thought this was strange so I pulled the pads from my mountain BB7s and they do not have this weird wear pattern.
    Other than one being the BB7 Mtn and one being the BB7 Road, the other differences are that I am running 180mm rotors on the MTB and 160mm rotors on the Weekender and the MTB has Alligator pads while the Weekender has the stock Avid pads. I don't see how either of these things would affect the pad wear. I have heard that different pads can make all of the difference with noise, but I think that generally applies to squealing, not weird grinding noises.
    Please see my photos below which show the MTB pads side by side with the Road pads and the brackets that were used to mount the MTB brakes vs. the Road brakes (Note that the MTB pads are smooth and the Road pads have deep grooves in them). I will also say that I set up the MTBs myself and have never had an issue, so I can only assume that the shop did something wrong when they were setting these up and I am wondering if they used the wrong mounting brackets?
    Looking forward to your input.
    Thanks!
    BB7 Road - Noise Issues-img_5897.jpgBB7 Road - Noise Issues-img_5898.jpgBB7 Road - Noise Issues-img_5900.jpgBB7 Road - Noise Issues-img_5901.jpg
    Reputation: Lombard's Avatar
    May 2014
    I would try replacing your Avid pads with the same Alligator pads you use on your mountain bike. Then set them up so they are aligned and don't cause a wear groove.
    Russian Troll Farmer
    Sep 2016
    From extensive automotive experience, I can tell you that disc brake noise is usually either from pad material (grinding), or from vibration of the pad inside the caliper (squealing).
    You didn't show the discs. Is the braking surface ABSOLUTELY smooth? Are there possibly burrs left on any holes/slots? Also, was all the machining oil removed when the pads were set in? I've bought drilled/slotted automotive rotors in the past that needed resurfacing straight out of the box.
    "L'enfer, c'est les autres"
    Apr 2014
    So, I sanded the rotors and the pads down. Then I put everything back together, made sure the calipers were properly aligned and did the recommended bedding procedure for these brakes. I am getting the same results. Some squealing, but mostly grinding noises and weird braking vibrations sometimes as well.
    I have considered replacing with the same pads I have in my MTB BB7s, but I feel like there is more to this issue than the pads given the strange grooves on the pads and the braking vibrations that I sometimes experience.
    Anybody else have any input?
    Thanks.
    May 2014
    Quote Originally Posted by magnato1 View Post
    Thanks.
    None other than my previous advice in post #2.
  1. Replies: 6
    Last Post: 01-09-2015, 06:08 AM
  2. Brifters that work well with BB7 road disc
    By 29Again in forum Cyclocross
    Last Post: 11-07-2012, 07:29 PM
  3. Avid BB7-road help
    By madonenm in forum Commuting, Touring and Ride Reports
    Last Post: 03-23-2010, 12:16 PM
  4. Avid BB7 road disc brakes question
    By nonsleepingjon in forum General Cycling Discussion
    Last Post: 09-09-2008, 10:54 AM
  5. Avid BB7 disc road help
    By crank it in forum Cyclocross
    Last Post: 04-29-2006, 05:03 AM
