Results 1 to 16 of 16
    Sep 2008
    Best headset to upgrade from Aheadset to use carbon fork made for integral bearings?
    How to convert traditional ball bearing race, Aheadset headset to use carbon fork (made for integrated headsets). I have a Fuji Newest with one of the heaviest 1-1/8" front forks ever manufactured, so I bought a used Look 566 1-1/8" front fork. What is the best replacement headset that I should buy in order to use this fork?
    Attached Thumbnails Attached Thumbnails Best headset to upgrade from Aheadset to use carbon fork made for integral bearings?-14433_1_.jpg   Best headset to upgrade from Aheadset to use carbon fork made for integral bearings?-img_4349.jpg
    Pullin my trigger.
    Nov 2008
    The answer to that is simply. "Chris King".
    There you go.
    **** this forum! You guys are a bunch of *******s! -2wheelsrule
    and yet another unnecessary A**hole! go F*** youself! -rabochuffo
    Sep 2008
    The lip of the Aheadset hits the flat top of the fork before the built-in crown race touches the Aheadset bearings. I am assuming that I will need to pop out the headset and replace with one that has sealed bearings.
    The website says "The 100 percent carbon, single-piece fork uses Look's patented integrated conical carbon crown, with 45-degree bearing angle".
    What "45-degree bearing angle" traditional outboard bearing headset model from Chris King, Cane Creek or FSA would you recommend?
    Quote Originally Posted by tihsepa View Post
    There you go.
    Pullin my trigger.
    Nov 2008
    Just a 1 1/8" NoThreadset. Thats basicly what you showed above.
    The Cane Creek 40 is nice also but its not a King.
    Jun 2007
    Quote Originally Posted by Erik_A View Post
    There's no such thing as a "fork made for integrated headsets". That fork is made for threadless headsets, but not all threadless headsets are "integrated". There are several types and the type of threadless headset ("integrated - cane creek type", "integrated campy type", zero stack/press in internal cups, conventional/press in external cups, etc.) is determined by the frame (head tube). Just get any threadless headset in your price point that is compatible with your frame and you're good to go.
    But maybe I'm missing something. The headset you posted looks like "conventional/external cups" to me which leads me to ask - why not just use the headset that's already in the frame? Is the new fork's steer tube different diameter than the old one? Again, the fork - it's steer tube - regardless of material it's made of, doesn't determine the type of headset you need.
    [edit .... sorry I just noticed your second post in the thread]. Your new fork isn't for an integrated headset - it simply has an integrated lower race. Most forks require a race that is pressed down the steer tube on to the fork crown. If you look at your old fork, you'll probably see it. Annnnnnyyyy way.....
    I would be surprised if your current headset wouldn't work, assuming it has a lower bearing angle that matches that integrated race on the fork. If so, I don't know why you couldn't use it, regardless of whether it's a caged bearing type or sealed bearing type. On the other hand, just get any headset you like with the lower bearing angle that matches that race and is compatable with your frame.
    Sep 2010
    Quote Originally Posted by Camilo View Post
    I was just thinking it'd need a new race on the fork?
    Reputation: PlatyPius's Avatar
    Feb 2009
    The bottom race is integrated on the fork. Whatever headset you find that will work (if any) will definitely need to be a cartridge bearing one. However, most traditional headsets have a 36° angle bearing, not a 45°. You'll either need to be VERY friendly with your local shop, or you'll need to chalk this one up as a bad purchase.
    Disclaimer: I own a bike shop. Yes, I'm biased.
    Other countries need to stop hatin' or we'll unfriend them
    . - Christine
    Apparently I left my reading comprehension glasses in my ass. - DrRoebuck
    Still, it felt great and I felt like I was sitting on some kind of vibrator -Touch0Gray
    and yet another unnecessary A**hole! go F*** youself! - some loser
    Sep 2008
    Thanks - It is a caged bearing headset pressed in.
    Jun 2007
    Quote Originally Posted by adam_mac84 View Post
    Ordinarily I'd say that's exactly it - get a crown race that is appropriate for your headset bearings and press it down onto the new fork's crown... or do what I did, carefully scavange the crown race off the old fork and put it on the new one. BUT, your Look fork says it comes with an integrated crown race w/ 45 degree contact angle. Most conventional threadless headsets (unless I'm mistaken - you should research on FSA and/or Cane Creek) come with 36 degree berarings like Platypius said. I don't know if you could put a new crown race w/ 36 degree angle onto it.
    Now I'm thinking that I was wrong when I stated that there's no such thing as a fork made for an integrated headset! The only headset I'm aware of that has a 45 degree lower contact angle is (I could be wrong!) a "campy" standard integrated headset. So, maybe the Look fork is specifically made for that.
    OK, what I'd do is call up FSA or Cane Creek and ask them if they have a suggestion or can sell you a lower bearing that is compatible with your 45 degree fork crown race and your traditional press-in threadless headset. Or maybe they'll tell you that you could simply place a new crown race onto that fork.
    Just free-associating here, do not give this any credibility: maybe you could carefully remove/grind/scrape off the crown race that is part of the fork to make the surface accept a new crown race.
    After you call them, please post back - I'd be interested in the solution!
    Sep 2008
    I bought a Cane Creek S-8 headset - will report back when it arrives.
    From China for $30: Cane Creek s 8 s 8 Headset 28 6mm 1 1 8 " New | eBay
    'brifter' is a lame word.
    pretty sure that's not gonna work.
    2012 Trek Cronus Ultimate w/ SRAM Red Black
    2010 Cervelo T1 sprint bike
    2011 Cervelo P2 pursuit bike
    FMF 24" cruiser
    Bianchi Pista road fixed gear
    1949 Columbia 26" cruiser w/ SRM & fenders...and rust
    '05 Suzuki DRZ400SM
    Feb 2009
    From the US:
    Cane Creek S-8 Headset in Tree Fort Bikes Headsets (cat124)
    Ain't gonna work, BTW...
    . - Christine
    Sep 2008
    Platypus- how come the Cane Creek S-8 won't work - it has the 45 deg. Bearings?
    Quote Originally Posted by PlatyPius View Post
    Feb 2009
    It has 45° bearings? If so, it'll work. The info on my distributor website says it's 36°. Wouldn't be the first time the distributor has been wrong, though...
    . - Christine
    Mar 2007
    One of the numbers coincides with the angle on the inside of the bearing (the part that sits on the crown race), the other angle represents the angle on the outside of the cartridge (the part that rests in the headtube or pressed in cups.) I'm guessing that you'll need a headset with bearings that say "45 x 45" on the side, not "36 x 45."
    I'm pretty sure the interface between the frame (or cups) and the cartridge bearing is 45 degrees for most headsets, and if true, that means the "36" stamped on the side of that cartridge bearing is referring to the internal angle and this means that it WILL NOT work with your 45 degree crown race. 45 x 45 headset bearings are available, so find one of those and swap it out for the lower bearing on your existing headset, and you may just be in business.
    -Jeremy
    Sep 2008
    Thanks jeremy-
    Quote Originally Posted by Tunnelrat81 View Post
    -Jeremy
