Results 1 to 11 of 11
    Reputation: pulser955's Avatar
    Apr 2009
    Best non disc cross brakes?
    So I have a cheep cross bike that I converted to a town bike a few years ago that I want to turn back in to a cross/gravel bike. Whats better V or cantilever brakes?
    Apr 2014
    It depends. Whatever you decide to choose, make sure it matches the cable pull of your levers. Or you risk poor braking with no modulation or grabby brakes. There are pros & cons to both depending on how you plan on using them.
    I've been using mine mostly on the road & I find the stopping power of mini-v's very good especially on downhills.
    coaster
    Reputation: Lelandjt's Avatar
    Sep 2008
    TRP CX8.4
    They work great and stay in adjustment. Also look nice and light.
    There's more to it than just v vs Canti as some of each suck and some are good but generally speaking V brakes are stronger. I've read modulation is interior with V but haven't really noticed a difference myself.
    You also have to consider clearance. Canti's give you more. But you need to be using pretty massive tires for most V to be a problem so chances are clearance wouldn't be an issue.
    Reputation: Lombard's Avatar
    May 2014
    Unless I am mistaken, if you are using road bars with STI shifters, they won't pull enough cable for V-brakes to give you effective braking. So cantilevers are your only option.
    -- Warren Buffett
    Jan 2010
    I've been happy with Avid Shorty brakes with my road levers. They offer lots of adjustment and standard pad holders. They come with 3 different straddle cable lengths that allows you to tailor the brakes to the levers and the type of "feel" that you want.
    There's sometimes a buggy.
    One.
    Apr 2009
    Thanks guys TRP Vs it is.
    Huge in Japan
    Reputation: craiger_ny's Avatar
    Jun 2014
    They make helper pulleys for them. I don't know the ratio of the TRP CX8.4 though, they don't look like the same length of a 'conventional' v brake.
    Interwebs bumpersticker goes here
    coaster
    Sep 2008
    Here's a table with V-brake arm lengths:
    Tech Tip: V-Brake Arm Lengths – GRAVELBIKE
    There are also 3 different amounts of cable pull depending on what road brake lever you have. Match levers with brakes to achieve the power, snappiness, and rim/pad clearance you desire. I like TRP CX8.4s with Shimano 11spd levers but people with weaker hands may like a 90 or 95mm brake with these levers that pull the most cable of any road brake lever. Of course they'll have less pad clearance.
    May 2012
    I have Shimano V-brakes of which I forget the model with 5700 levers and Kool Stop pads on my Surly. These brakes work super. Better than my 6800 brakes on another bike.
    Jun 2008
    My vote is for Paul Mini Moto's. Same idea as TRP, but much nicer quality and serviceable in the long run.
  1. Velo tests aero drag of disc vs. non-disc Tarmac
    By OldChipper in forum Bikes, Frames and Forks
    Last Post: 01-26-2015, 11:56 AM
  2. Disc brakes are awesome!!! / Disc brakes are Awesome???
    By metoou2 in forum Components, Wrenching
    Last Post: 01-18-2013, 04:28 PM
  3. Best 'cross bike under $2k, with disc brakes?
    By JChasse in forum Cyclocross
    Last Post: 10-20-2011, 05:00 PM
  4. Wheel Building - Disc / Non-Disc Hubs
    By snowedin in forum Components, Wrenching
    Last Post: 01-28-2011, 09:02 PM
  5. Replies: 27
    Last Post: 07-20-2007, 11:50 PM
