I use the below on my bikes. Can someone explain to me the differences between the 2 greases? I use the Shimaono grease in the threads of the BB and the teflon grease elsewhere (screw threads, bearings).
Use the Loctite 222 (which came with some Festo stuff from work) on small screws in dropouts and jockey wheels.
Your benefits:
Ideal for low-strength threadlocking of adjusting screws, countersunk head screws and set screws
Good on low strength metals which could break during disassembly, e.g. aluminium or brass
Technical Data:
Maximum thread size: Up to M36
Strength: Low
Breakaway torque M10 bolts: 6Nm
Fixture time steel: 15 min.
Fixture time brass: 8 min.
Fixture time stainless steel: 360 min.
Service temperature range: -55°C - +150°C
 Originally Posted by Pitts Pilot
...just recently, I've found that my removable valve cores in my Continental tubes keep unscrewing when I unscrew the (Lezyne) pump head and they blast across the room. When that happens (and I can find it,) I put some Loc-Tite on, as I don't need them to be removable.
I hadn't thought of that. My Lezyne pump has done that with the valve cores on my Vitoria tubs. It's a massive f*cking pain in the 'rse when that happens in the middle of gluing a tub.
Repped
Repped
If you read the instructions for your pump you would have known form the start. It's one of the first things in big bold letters. RTFM
Also an excellent tip but this section would be fairly low on content if we all read the manual before we f@cked things up.
HAHAHAHAHAHAHAHAHAHAHAHAHA!!!!!!
Post of the year!
Actually, that's how a thread locker works. Threads are not perfectly round or have perfectly formed peaks and valleys. Loctite and other compounds fill the imperfections. After it's cured, it prevents the screw from rotating. Contrary to what some people think, it isn't a glue.
Grease actually works in a similar way. Many people think that by using grease the parts might come loose, but the opposite is true. While grease doesn't "cure" like thread lockers, it fills in the gaps & imperfections & has the added benefits of preventing rust & making it easier to disassemble when you need to. Kerry said that nothing falls off his bike. Well that's not quite true for me. I fall off on rare occasions, but I try not to make a habit of it. Maybe I should use thread locker on my ass.
You know that little thing in your head that keeps you from saying things you shouldn't? ......Yeah, I don't have one of those..
Elmira > Taiwan > Elmira
You know, hitting the quote button is easier than doing Cut and Paste...
Using gease or an anti-seize compound allows fasteners to be properly torqued. That's why they tend not to come loose.
2005 Ritchey BreakAway (steel)
Full Campagnolo compact drivetrain - Chorus 11sp
(50, 34 & 12-29)
Proton wheels
Cateye CC-TR300TW V3
Ritchey fork, stem, headset, bars and seatpost
Fizik Gobi saddle and bar tape
BeBop Pedals
Yup! That's another reason. Happy that I used the quote button for this one?
It makes it easier to follow where things come from and the accompanying train of thought...
(50, 34 & 12-29)
Proton wheels
BeBop Pedals
Someplace where I've used Loctite to great effect is on my lawn mower & snow blower handles. Those dang things were always coming loose even if I used grease. They both vibrate like hell. Nice, cushy bar tape keeps my hands from going numb.
- You may not post replies
- You may not edit your posts
Forum Rules
