Results 1 to 8 of 8
    Jun 2015
    Blue Thread lock ?
    Every once in a while I get a screw or bolt with Blue Lock tight stuff that is Dried on the threads. I have been using Regular Blue lock tight on some stuff but it doesn't dry thick like some of the stuff that comes already on some screws and bolts.
    What is the thicker Blue thread lock that is dried on threads ?
    Thanks
    Forever a Student
    Mar 2014
    It's pre-applied to bolts so that it speeds up assembly in factories.
    Basically the same stuff.
    use a torque wrench
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Jun 2015
    yep...that's it.
    Can I buy that stuff any where ?
    Forever a Student
    Mar 2014
    Doubtful. It's for manufacturers.
    If you don't like the liquid, you can use this stick stuff.
    use a torque wrench
    Jun 2015
    Cool
    Thanks
    Reputation: JCavilia's Avatar
    Sep 2005
    That's not really the same stuff. The pre-applied stuff you saw is a gummy stuff that dries in air after application, then leaves a gummy semi-solid. 248, like the liquid 242 you're accustomed to using, is an anaerobic adhesive that only cures in the absence of oxygen after assembly. The reason you've noted that it "doesn't dry thick" is that in the open air it never really cures at all. It's meant to be applied just before assembly, and it does cure when used that way. There's no special advantage to the pre-applied stuff except convenience.
    Have you ever been to Electric Ladyland?
    a real member's member
    Jul 2016
    holy crap! are we working on bikes or ... train cars?!
  1. Guaranteed thread lock here or worse
    By OES in forum General Cycling Discussion
    Last Post: 04-09-2009, 04:32 PM
  2. Replies: 7
    Last Post: 01-30-2008, 07:35 AM
  3. Blue Cheese Appreciation Thread
    By S2H in forum The Lounge
    Last Post: 02-21-2007, 06:38 PM
  4. Replies: 4
    Last Post: 09-20-2004, 09:34 AM
