Results 1 to 2 of 2
    Nov 2002
    Bontrager direct mount brakes
    Are these good or should I switch them out for Ultegra? I already ran into a couple of issues with them: wouldn't take Kool Stop pads without filing the slot in the pad where the retention pin fits in, and squeaky springs that needed a shot of WD40.
    Sent from my iPhone using Tapatalk Pro
    Dec 2005
    I had a 7 series Madone where I upgraded the Bontrager DM brakes to Shimano. That included the rear brake that was under the chainstays. I think they're definitely easier to set up and fine tune. I think performance (stopping power) was improved, but that could be wishful thinking. I'm pretty sure I put on new pads that came with the Shimano brakes.
    I have the Bontragers on my Emonda. I think the end of the allen bolts that center the brakes must be shaped like the point of a drill bit. If I barely tweak the bolt then the centering of the pads jumps, and I can't really fine tune it. Other than that, they work, they stop fine especially since I upgraded to the SwissStop Black Prince pads.
    If you switch to the Shimanos, I think the gains are there but minimal. If you don't have the Bontragers and are deciding which to buy, then I'd probably get Shimano.
  1. Replies: 0
    Last Post: 12-21-2016, 05:05 PM
  2. Carbon fork for direct (dual) mount caliper rim brakes
    By AndreSF in forum Components, Wrenching
    Last Post: 05-12-2016, 02:44 PM
  3. Direct mount brakes - brake lever compatibility
    By frons in forum Components, Wrenching
    Last Post: 08-20-2014, 06:15 AM
  4. new bontrager direct mount brakes
    By spartanbike in forum Trek
    Last Post: 08-01-2014, 09:28 AM
  5. Difference between direct mount and hangar mount?
    By shades9323 in forum Components, Wrenching
    Last Post: 01-30-2008, 07:17 AM
