Results 1 to 2 of 2
    Mar 2012
    Botton bracket cable guide, press fit.
    I have a 2013 caad 10 and I snapped the nub off the cable guide. Its the press fit without a screw.
    Should I try to locate one from a cannondale dealer?
    or
    Glue the one I have onto the frame? Its still perfect, I just cant get it to attach to the frame anymore. Would glue or goop work?
    I gotta call around and think it might take a while to get one. I really want to get the bike back on the road
    Dec 2006
    Have you tried seeing if the guide stays in place without the nub? You might be able to get away with that while a new piece is on order.
    Or, stick it on with double sided tape, available at many hardware stores. It too, should hold long enough while you wait for a replacement.
    In either case, there's no down time for you.
  1. OEH Botton
    By JaeP in forum The Lounge
    Last Post: 04-20-2010, 12:21 PM
  2. bottom bracket cable guide install
    By buddhistwithafancybicycle in forum Components, Wrenching
    Last Post: 01-23-2007, 11:23 AM
  3. Bottom Bracket Cable Guide Question - Specialized Roubaix
    By tiger in forum Components, Wrenching
    Last Post: 01-20-2006, 08:20 AM
  4. Specialized Roubaix bottom bracket cable guide question
    By Bloatedpig in forum Specialized
    Last Post: 10-27-2005, 10:06 AM
  5. R2000 Bottom Bracket Cable Guide ...
    By burger in forum Cannondale
    Last Post: 05-28-2004, 10:21 AM
