Results 1 to 6 of 6
    Oct 2007
    brake pad replacement
    Should brake pads be replaced even if they are not worn to the line (Dura Ace). Bike is two years old with 9,000 mi. and we ride a lot of hills.
    A friend with new Ultegra commented on how good the brakes were. Was wondering if that was because of the new pads.
    kytyree
    Guest
    Clean them and make small adjustments to account for the wear and you should be able to use them to the line.
    eRacer
    Reputation: jmlapoint's Avatar
    Sep 2008
    If you have adequate pad remaining, and you should at 9,000 miles, clean the pads and the rims....cables need a little lube occassionally and so do pivot points on the brakes.
    New pads will not make your brakes better if your present pads are OK.+
    John Lapoint / San Diego
    God is Great, Beer is Good, and People are Crazy!
    Jan 2009
    I agree with the others that you should be able to use the pads until they wear down to the root of the grooves,
    However, they also harden a bit with age and oxidation so remove your wheels and use a file to freshen the surface (don't use emory, since it'll leave bits of abrasive) or if they're fairly close to the end, replace them now.
    fb
    www.chain-l.com
    Solving any problem requires understanding the underlying cause
    Oct 2007
    Brake pads
    Thanks all for your comments. Will try the file. Already clean brake surface of rims with a Scotch Pad and soapy water as needed.
    Resident Curmudgeon
    Nov 2005
    If it ain't broke - don't fix it.
