Results 1 to 25 of 27
Thread: Brake pads
    Apr 2011
    Brake pads
    I have Tektro brakes on my Cannondale Synapse what style of pads do I need and what should I get for pads? I live in area that has mountains and lots of hills. I see pads that are compatible with Shimano or Campagnolo and I am not sure about the Tektro.
    Thanks
    Brian
    Militant commuter
    Reputation: SilverStar's Avatar
    Jan 2008
    Shimano-style pads. You'll get a lot of positive feedback about Koolstop "salmon" pads...they rock! Of course, if you're running carbon rims you want to stick with the pads recommended by your rim manufacturer.
    "Luminous beings are we...not this crude matter!"
    May 2009
    I'm a big fan of Kool Stop Salmons too.
    There is one decision left to make. Sort of. Inexpensive brakes sometimes come with a pad with a post sticking out of it. The whole thing is installed or removed as a unit. If you have that, make sure you get the holders too when you get your kickass new brake pads.
    Resident Curmudgeon
    Nov 2005
    ^^^^^^^^^this^^^^^^^^^
    You know that little thing in your head that keeps you from saying things you shouldn't? ......Yeah, I don't have one of those..
    Apr 2011
    Thanks
    Reputation: Newnan3's Avatar
    Jul 2011
    Hows the wear life on the Koolstop pads?
    May 2009
    IME, about the same as every other brake pad. I don't keep brilliant records of this stuff and it's pretty subjective. But, that's how it seems to me.
    Reputation: JCavilia's Avatar
    Sep 2005
    Quote Originally Posted by Newnan3 View Post
    I've been using them, and their predecessors (Scott Matthauser, which originally developed the pad compound) for almost 40 years. They last a long time, and they work very well. And they're not expensive.
    Get one of the models that have the spherical washers, which allow easy adjustment of the precise angle.
    This one
    is better than this one
    Kool Stop Salmon Brake Pads for Bicycles from Harris Cyclery
    Reputation: GRAVELBIKE's Avatar
    Sep 2011
    My favorites are Kool-Stop salmon. You can get them with holders, or as inserts only. Your LBS should be able to steer you towards the right ones for your particular calipers.
    GRAVELBIKE.COM - ride everything
    Jan 2011
    The best brake pad compound for aluminum rims is Swisstop Green but I'm not sure that they make a version for canti's.
    Pitts Pilot
    Dec 2011
    When you say Swisstop Green is best for aluminum, do you mean braking performance or rim wear or both or other? They're pretty pricey, but if my rims will last longer, I'm all for it. I do LOADS of steep, wet braking.
    Jan 2011
    I was mainly refering to braking performance both wet and dry. I haven't noticed any issues with increased rim wear and the manufacturer claims that the green compound is easy on rim surfaces.
    Reputation: nightfend's Avatar
    Mar 2009
    7900 Dura-ace pads are very good for aluminum wheelsets.
    Jul 2007
    Quote Originally Posted by nightfend View Post
    +1
    Pitts Pilot
    Dec 2011
    I recently switched from the Dura-Ace pad, which I liked just fine, to the Yokozuna Scott-Matthauser. I find them much the same in dry conditions, but much better on my frequent, wet descents. And they're only $7.00.
    Jul 2011
    Im interested in trying the salmon kool stops because Ive always heard great things about them.
    My 105 pads seem to be holding up fine for now however.....
    Reputation: old'n'slow's Avatar
    Sep 2007
    Does anyone know if Shimano made a composition change in the 7900 pads compaired to the 7800 pads?
    The reason I ask - I found the 7800 pads to be WAY inferior to the Kool Stop Salmon pads on aluminium rims, but would be willing to try the 7900 pads if improved.
    Mar 2009
    Quote Originally Posted by old'n'slow View Post
    7900 pads use a different material. Also, the older 7800 pads went through two iterations, and the later versions were better, especially under wet conditions. But, I find the 7900 pads are a little better than the older 7800's. I use the 7900's now on both my older Shimano and newer shimano brakes.
    Jun 2003
    Generally Shimano pads are too hard and harden with age.
    My Campy pads were excellent when new but have gradually hardened with age.
    I like Koolstop salmon pads best of any I've tried.
    Reputation: thalo's Avatar
    Jul 2011
    There has been much talk about Kool Stop Salmon pads in this thread, and others. Does anyone know the difference between the salmon and black. I know that the packaging shows the black for dry and salmon for wet, but what is the difference in compound and experience? Is salmon softer? Does it wear faster?
    I live in a dry area, and am not macho enough to ride in wet conditions if I don't have to, so are blacks good enough or salmons superior regardless of condition?
    Jun 2003
    Quote Originally Posted by thalo View Post
    The salmon pads are softer and brake better. I can't tell that they wear any faster but I'm not a long time user of the salmon pads. In my experiences the Koolstop black pads are softer than Shimano's but the salmon pads are much softer than either.
    Reputation: DIRT BOY's Avatar
    Aug 2002
    Quote Originally Posted by LePatron View Post
    Green is for ceramic braking surfaces. But they can be used. I love Swiss stop blacks
    DIRT BOY
    "Pain is a big fat creature riding on your back. The farther you pedal, the heavier he feels. The harder you push, the tighter he squeezes your chest. The steeper the climb, the deeper he digs his jagged, sharp claws into your muscles." - Scott Martin
    Aug 2002
    My favorite and best pads I have used for Dry/Normal conditions is Swiss Stop Black compound. Swiss Stop Green are also for aluminum rims but Ceramic coated ones or wet conditions. But may be used on regular aluminum, but might wear the rims a bit.
    Swiss Stop Yellow is the best for Carbon rims and can be used for switching between carbon and aluminum braking surfaces too.
    Now wet or off road conditions, nothing beats Koolstop Salmon pads. Hands down work awesome on wet rims!
    DIRT BOY
    Oct 2012
    Talking Which is better !!
    Quote Originally Posted by JCavilia View Post
    This one
    I have MAVIC AKSIUM alliminum which pads you think is the better for me I ride on rain ! Got shimano 105 on my 11"Scott team !!
    Oct 2012
    I sow koolstop salman with black !! Will this be good or just salmon !!! Which is better for alloy rims swisstop or koolstop
  1. Campagnolo brake pads Shimano brake pad holders
    By username in forum Components, Wrenching
    Last Post: 06-28-2011, 04:03 AM
  2. Brake pads
    By TBaGZ in forum Components, Wrenching
    Last Post: 06-19-2010, 07:44 AM
  3. Brake pads?
    By TallBikeMike in forum Beginner's Corner
    Last Post: 04-13-2010, 08:27 PM
  4. Kool Stop brake pads, carbon pads on alu?
    By cclaeys in forum Components, Wrenching
    Last Post: 10-30-2008, 07:08 PM
  5. Best brake pads
    By filtersweep in forum Components, Wrenching
    Last Post: 05-31-2006, 03:41 PM
