Results 1 to 9 of 9
    a real member's member
    Jul 2016
    broke the rear axle on my old grocery getter
    i saw my bike sittin' there with a rear flat after i just used it yesterday, and i said, "shît! another ******* flat! well, at least i made it home this time."
    after i removed the wheel, i felt the axle all wobbly in my hands and said, "whaaaa??? what the ********************! how in the ******** can this be so loose??? oh ... oh ... the axle broke. daaaaaaamn. hey, good thing i got a flat!"
    this is the first time this has happened to me by me. i've had that hub/wheel in this bike for almost ten years. fortunately, all seems well with the rest of the hub. cones and races look great. guess i'll be spending the weekend on an axle* hunt.
    * 10mm x 26tpi x 133mm
    '75 motobécane grand record
    Banned forever.....or not
    Aug 2002
    I've never broken an axle on a freewheel hub, but I must have bent three or four. They still needed replacing...…...Thank god for cassettes.....133mm for 126mm spacing...(Nobody is going to carry something like that, in stock, anymore)
    Dogbert.
    I>U
    Dec 2006
    I broke several freewheel style hub rear axles and in fact, they were Campy. And I don't weigh squat. Fortunately, you'll get a new axle and enjoy another 10 years.
    Russian Troll Farmer
    Sep 2016
    Quote Originally Posted by blackfrancois View Post
    You are mixing metric and English dimensions. Being French, that axle would be only metric. Your pitch is likely 1.0mm/thread, or 25.4 tpi. Look for an M10x1.0 thread.
    BTW, 26 tpi is a common Whitworth standard, whereas 24 tpi is a common English standard. You generally only see 26 tpi stuff on Raleigh, and sometimes on other bikes built by Raleigh. Otherwise, the only other bikes that use 26 tpi are at least 80 years old.
    "L'enfer, c'est les autres"
    Jul 2016
    Quote Originally Posted by MR_GRUMPY View Post
    Nobody is going to carry something like that, in stock, anymore.
    most bike shops will have one on hand, like the wheels mfg axle-08, which is 10mmx26tpi. but it will have to be cut down with a hacksaw to fit my frame. (if you put a cone or nut inside the saw mark, you can clean the sawed threads when the nut is removed.)
    10mmx26tpi is the old campy standard. for you trivia buffs, it's also the threading of a campy dropout hanger.
    until i can find a nos campy one, i'll try to find a used one in the bin at the lbs (hopefully, knock wood).
    Jul 2016
    Quote Originally Posted by Peter P. View Post
    "several"? really? do you attribute it to a particular event or wide rear cluster (7-8 speed) putting a lot of stress on the axle?
    what's so weird to me is my bike frame hasn't been widened (it's still only wide enough for a 5-speed freewheel), and the dropouts are aligned properly.
    Reputation: velodog's Avatar
    Sep 2007
    Too old to ride plastic
    Jul 2016
    recycled cycles in seattle used to have three big plastic bins of used axles. i guess it's been a while since i needed one, 'cause now they just have a little drawer of them. but what used to take a while to scrounge through now only took five minutes to find a good chromoly axle that worked for me. the nice guy behind the counter sawed it down to 133mm for me for a grand total of $15 ... and he threw in a nice 3mm aluminum washer and seven tube patches. score!
    Nov 2014
    Maybe buy a Wheels MFG axle to have on hand. If you did it once, you will bend or break it again"
  1. 1 X ? w/ thumb shifter - Volpe converted to grocery getter
    By head in forum Components, Wrenching
    Last Post: 04-15-2016, 08:58 AM
  2. Casseroll grocery getter help
    By FlynG in forum Commuting, Touring and Ride Reports
    Last Post: 11-22-2009, 08:49 AM
  3. Newest little grocery getter
    By HMBAtrail in forum Bikes, Frames and Forks
    Last Post: 06-18-2009, 10:13 AM
  4. grocery getter
    By Henry Chinaski in forum Commuting, Touring and Ride Reports
    Last Post: 04-24-2008, 09:21 PM
  5. Colnago grocery getter?
    By Dave Hickey in forum General Cycling Discussion
    Last Post: 10-07-2004, 02:51 PM
