Results 1 to 14 of 14
    crj
    crj is offline
    Jul 2006
    Cable Housing Cutters @ Lowe's
    Did not like the way the Park cutters squished the housing, so I tried something else. Kobalt brand cable cutters from Lowe's priced @ $16.98 made a perfect cut with only a little grinding to square up the end. They didn't mash the inner liner or leave the frayed housing protruding. The item # is 107385 -9.5" cable cutting pliers. Side note use on brake housing's only, shifter housing's are too tough.
    "If it ain't broke the government will keep fixing it till it is."
    Apr 2010
    crap, i just got a park tool for $30.
    Everything else I have from Park has been flawless and worth the money
    It's a fire road.............
    I'm on a road bike..........
    They have enough in common to blast down it.
    Reputation: EBrider's Avatar
    Aug 2009
    I have the Park tool and it works fine. It squeezes the end, but there is a notch below the cutting blade to straighten it out.
    Grinding the end sounds like a lot more work to me.
    Nov 2006
    Shimanos are the best.
    Jul 2008
    Dremel tool with a cutting wheel for me. 1001 other uses too.
    Old and Fixed, Moderator
    Jan 2002
    Quote Originally Posted by Blue CheeseHead
    +1 that's what I use.....if I'm too lazy to get the Dremel out, I stick an old piece of cable in the housing and cut it off with my old cutters....it works fine...
    Dave Hickey/ Fort Worth
    Sep 2007
    Std Linemans plyers
    You know, I cut my housings with a standard pair of linemans plyers and never had a problem. No crushing or oblonging or anything. I have a pointed awl that I poke in the end afterwards. Dykes don't have enough power for me.
    Nov 2009
    Based on a lot of threads on this subject in different bike forums, the clear cut favorite is Felco.
    Jeff
    Reputation: Kuma601's Avatar
    Quote Originally Posted by Dave Hickey
    This +1. It is a bit harder to cut but afterwards, it is ready to go, just feed the cable through.
    Resident Curmudgeon
    Nov 2005
    I bought some Nashbar cable cutters more than 20 years ago. They only cost a few $$ then & they work fine.
    Reputation: PlatyPius's Avatar
    Feb 2009
    Quote Originally Posted by EBrider
    I put all brake cable housing on the grinder to make sure the end is flat and that the cable will move freely.
    Other countries need to stop hatin' or we'll unfriend them. - Christine
    Apparently I left my reading comprehension glasses in my ass. - DrRoebuck
    Still, it felt great and I felt like I was sitting on some kind of vibrator -Touch0Gray
    uhhhh, what?
    Apr 2002
    Quote Originally Posted by kbiker3111
    Nope - that would be Felco.
    plus a change, plus c'est la m'me chose - alphonse karr
    Nov 2008
    Quote Originally Posted by supercorsa
    Which one? They have many cable cutters.
    http://www.felcostore.com/wirecablecutters
    Embrace the fact that everyone on these forums has their own unique desires, needs, experiences and environment so what works for you may not work for others.
    Old, slow, and fat.
    Reputation: MShaw's Avatar
    Jun 2003
    I'm gonna disagree. One of the shops I worked in had a pair. Blech. Give me my old Shimano cutters from the early 90s first. In fact, I brought em in from home and used those instead!
    I bought a new pair of Shimano cutters a few years back 'cause my 20 YO ones were 'wearing out.' The new ones are in the box in my toolbox while the old ones keep on cutting just fine.
    Depending on how anal ya are, grinding the end of the brake housing flat isn't too hard to do regardless of what cutters ya use.
    M
    I've moved back to NoVA. PLEASE change the weather!
