Results 1 to 4 of 4
    Nov 2008
    Cable stop on carbon frame coming loose
    I have a '08 Bianchi 928SL. On the downtube there are small metal plates to which the cable stops are riveted. A rivet on one of the cable stops is coming loose. Does anyone know how to repair? If I knew the rivet size I could probably find a replacement and have it drilled and replaced. Or is there some type of epoxy for the metal-to-metal interface?
    Thougts/advice would be appreciated.
    'brifter' is a lame word.
    Drill rivet, replace rivet. Epoxy or JBWeld in addition will help.
    I work for some bike racers
    and a bunch of skateboards
    Nov 2008
    Thanks
    Thanks. Do you know if this is some standard size rivet? Or how I can find the size I would need?
    If you drill it you'll end up removing the part that falls into the frame, you can use that to find the size. I'm not sure exactly what size your frame has, but that should give you the info you need. Or measure the hole in the housing stop.
  1. Help! shifter cable end stuck in cable stop.
    By norman.j.singh in forum Components, Wrenching
    Last Post: 12-11-2013, 12:20 PM
  2. Loose cable stop on C-50
    By ddesmonts in forum Colnago
    Last Post: 03-30-2010, 07:25 AM
  3. Replies: 9
    Last Post: 12-12-2008, 03:09 PM
  4. Cable stop that doesn't stop the cable?
    By winstonc in forum Cyclocross
    Last Post: 08-09-2005, 04:43 PM
  5. stupid cleats!!!!!! stop coming loose!!
    By bigd in forum General Cycling Discussion
    Last Post: 12-29-2004, 07:50 PM
