Results 1 to 11 of 11
    Nov 2011
    Campa Ergo lever problem
    I'm installing a pair of 10sp Chorus levers, but when I install the front brake, it pulls the lever too far back. Anyone know what to do?
    Here's the left lever:
    And here's how it's supposed to look (right lever):
    Jul 2011
    Squeeze the brake handle and slide the Caliper QR pin inboard.
    Here are some instructions that may help you.
    Workshop: How To Fit Campagnolo Ergo Levers - BikeRadar
    You can leave the hoods on to do the install, but as you've pulled them, this should help to put them back on
    CAMPAGNOLO - Ergopower? Ultra Shift? support installation -- Montaggio dei copri supporto. - YouTube
    Rubbing alcohol works well.
    One more tip if you have issues running the shifter cable up through the body, press the thumb shift down all the way (this can give you a clear path to thread the cable).
    Reputation: JCavilia's Avatar
    Sep 2005
    Quote Originally Posted by mikerp View Post
    Right. The shift lever isn't too far back; the brake lever is too far out, because you have that pin in the quick-release position that opens the caliper for easier wheel removal.
    Have you ever been to Electric Ladyland?
    AC0
    AC0 is offline
    Aug 2010
    Attached Thumbnails Attached Thumbnails Campa Ergo lever problem-chorus_lever3.jpg
    Nov 2011
    mikerp, thanks man!! Never knew that was a QR - suddenly feel very newbie-ish
    Nov 2011
    Overwhelmed by your helpfullness guys! In some forums people would be screaming at me right now for asking such a stupid question ;-)
    Thanks!
    Jul 2011
    Quote Originally Posted by megl View Post
    You're welcome, I added some more info to my first post to help you get the hoods on.
    Make sure to tighten the clamps well (the band clamps have arrows on them pointing up) Off the top of my head they take 10nm.
    BTW I looked at your photo and wondered, "I'm not seeing the issue, it's just as it should look with the QR pin out"
    Nov 2011
    Thanks! I pulled them off 'cause they had to be changed. What's the alchohol substance he's using at the very beginning? Looks like a window cleaner
    Hehe - yeah, just rub it in ;-)
    Jul 2011
    I've read that it is rubbing alcohol (IPA), windex works as well (I'm under the impression it is mostly rubbing alcohol with some soap agent).
    Jun 2013
    soooo....
    Is this some social experiment? I've seen it on multiple forums, and you commented on how fast and friendly people have been.
    Nov 2011
    Quote Originally Posted by mjduct View Post
    soooo....
    I really don't see where you're getting at? I posted the question here and on weight weenies. Over there someone answered shortly and I said thanks (I don't suppose there's nothing wrong with saying thanks ... not even in your world?) In here several people seems willing to explain, point to guiding links and even post pictures about what some might think of as a quite stupid question. And even to a guy who mostly lurks and doesn't post much!!! I am quite frankly amazed with that. On most forums people like yourself would have jumped in much earlier and ruined the thread playing internet cop telling people what to do and what not to do. Mostly that kind of users doesn't know much about the subject at hand ...
    So I guess, you quickly turned it into a social experiment! Do you have anything to contribute to this thread? Perhaps you can give me a good explanation of why it is so horrible to post the same question to a problem I really needed solved on two different forums. So horrible you had to point it out?
    JCavilia, AC0 and mikerp thanks a lot for your help!!
  1. Replies: 10
    Last Post: 02-21-2009, 07:58 AM
  2. Problem installing Campa Veloce 2009 Ultrashifters
    By olli in forum Components, Wrenching
    Last Post: 02-19-2009, 08:47 AM
  3. Weird Campy ergo lever problem
    By elviento in forum Components, Wrenching
    Last Post: 10-11-2005, 08:17 AM
  4. Chorus Ergo lever problem
    By ridewt in forum Components, Wrenching
    Last Post: 03-18-2005, 04:36 AM
  5. how to tell if Ergo lever is 8 or 9 spd?
    By allezdude in forum Components, Wrenching
    Last Post: 10-31-2004, 10:43 PM
