Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
  1. #26
    Jan 2010
    Quote Originally Posted by mackgoo View Post
    All I know is that C Record has 14 balls to a set and their size is 7/32", so just a hair over the 3/16".
    I'm returning the BB and I have another one which I believe is correct on the way.
    Obviously the balls need to match the cups. If your balls are too big, then problems ensue. Good luck with your new ones.
    There's sometimes a buggy.
    One.
  2. #27
    a real member's member
    Jul 2016
    if i like and want to keep a bike, i do not use retainers for the bearings. i use loose bearings. in a normal bb that uses 1/4" balls in retainers, you fit two additional loose bearings on each side to spread the load a little more.
    if it's a cheaper bike (a flip), using retainers makes it a little easier to install the bb.
    if unsure about bearing size or count, look up the component on velobase. it's very easy to test bearing size and count by spinning the spindle in the dry cup full of bearings but without grease.
  3. #28
    Mar 2004
  4. #29
    Nov 2014
    Congrats. That looks more like the last Bianchi I had with cup and cone BB.
  5. #30
    Reputation: velodog's Avatar
    Sep 2007
    Done. Click image for larger version.
    So what was the issue that was causing the problem?
    Too old to ride plastic
  6. #31
    Mar 2004
    Wrong bearings.
  7. #32
    Sep 2007
    Wrong bearings.
    Good you got it sorted out.
  8. #33
    Reputation: JCavilia's Avatar
    Sep 2005
    Everybody says they want to have big balls, but sometimes your balls can be too big, I guess.
    This was kind of an interesting puzzle. Thanks for the entertainment and education. Glad you got it sorted.
    Have you ever been to Electric Ladyland?
  1. Campagnolo bottom bracket for Vitus 979?
    By Glyndwr in forum Retro-Classic
    Last Post: 06-12-2016, 01:06 PM
  2. Campagnolo 102mm bottom bracket
    By carbonite in forum Components, Wrenching
    Last Post: 01-03-2012, 06:12 AM
  3. Campagnolo bottom bracket problem
    By matchmaker in forum Components, Wrenching
    Last Post: 09-08-2009, 10:04 AM
  4. Campagnolo bottom Bracket
    By PHILWDB in forum Retro-Classic
    Last Post: 01-15-2007, 03:03 PM
  5. Campagnolo ACH Bottom Bracket
    By Carbonsnail in forum Components, Wrenching
    Last Post: 05-12-2006, 06:25 AM
