Results 1 to 4 of 4
    Jul 2017
    Campagnolo & Quarq
    Hi.
    I知 interested in buying a power meter and after reading a few reviews the Quarq power meter made the top of the list.
    Since I知 running the Campagnolo Athena Carbon 11 Speed group set there is this unfortunate detail that it is not possible to use Campagnolo chain rings with Quarq power meters as they are not compatible. There is also the Power2max Campy version with excellent reviews but it is rather expensive.
    I also consulted Quarq and they indicated it is still possible to pair Quarq PM with Campagnolo but I would need to use either SRAM chain rings or some third party chain rings.
    Since I do not have any experiences with other group sets and my technical know-how is limited I would appreciate your help with the following questions:
    1. I wonder whether SRAM chain rings are compatible with the rest of the Campagnolo components? Sadly I can not test that and I don稚 know anybody driving this setup.
    2. If it is possible to combine Quarq and Campagnolo, which Quarq model is suitable? What specs should I look for...BB30, 110 BCD with hidden bolt? Like this one?
    3. Which third party chain rings would you recommend that would be compatible with Quarq and would work with Campagnolo?
    4. Any other options?
    I知 aware that there are good pedal based options like PowerTap P1 or Vector 2 that would save me the trouble but at this point I知 primarily interested in the crank based PM (more consistency, durability, ).
    Thank you!
    Thomas
    Jan 2010
    There is nothing so proprietary about Campy drivetrains that other cranksets and chainrings won't work. I've used FSA, Truvativ and Shimano cranksets and rings without issue.
    So to answer your questions:
    1. Yes
    2. Any model that you want. Personally I'd choose the GXP spindle and the one with the commonest rings, standard 130 or 110 bcd. You'll obviously have to change the BB to fit your frame and whatever spindle option you've chosen.
    3. I've used FSA because I'm cheap. Others will chime in I'm sure.
    We just don稚 realize the most significant moments of our lives when they池e happening
    Back then I thought 努ell there'll be other days
    I didn稚 realize that was the only day
    There's sometimes a buggy.
    One.
    PMC
    PMC is offline
    I've used Praxis Works chain rings on a Campy 11 SR drivetrain with Campy chain and never had an issue. The Praxis rings were on a Power2Max PM and the combo was flawless the entire time I used it.
    Aug 2013
    Quote Originally Posted by bikerjulio View Post
    Me too. I know there is a whole bunch of fsa hate. But, I have two sets of their rings - one with about 25,000 miles and the other that is pretty new (1500 ish). Both are fine and 1/2 the cost of other rings.
  1. Quarq/Red Cranksets & Madone Compatibility - What have I got here?
    By cpecrivaine in forum Components, Wrenching
    Last Post: 08-08-2017, 12:22 PM
  2. Replies: 0
    Last Post: 01-29-2013, 04:31 AM
  3. Dear Heartbreaker &&)))***eDgE***(((&&
    By JohnHenry in forum The Lounge
    Last Post: 11-13-2007, 11:19 PM
  4. Replies: 2
    Last Post: 11-10-2007, 11:05 AM
