Results 1 to 2 of 2
    idk
    idk is offline
    Outward Bound
    Jul 2002
    Campy Centaur 9 speed triple f. derailleur 28.6
    Would there be any problem using this with a 10 speed triple system?
    a little...
    Notice that 10 speed derailleurs have a small plastic insert on the left side of the cage, making it slightly narrower. Unless your derailleur has a slot on the left side for this insert (should be only on Record FD), then it will be a bit wider than intended.
    There have been reports that it will work adequately, without the plastic insert. Of course, the 28.6mm clamp size must fit your frame.
  1. Campy Question / Veloce / Centaur
    By VEN in forum Components, Wrenching
    Last Post: 10-14-2004, 04:02 PM
  2. New features for 2005 Campy groupsets are finally official!!
    By AJS in forum Components, Wrenching
    Last Post: 09-05-2004, 02:59 AM
  3. Replies: 0
    Last Post: 09-04-2004, 02:51 PM
  4. Campy 8 speed question
    By zero85ZEN in forum Components, Wrenching
    Last Post: 05-26-2004, 08:02 AM
  5. Mixing Centaur, Record and Chorus 10 speed
    By bc165 in forum Campagnolo
    Last Post: 03-24-2004, 07:37 AM
