Results 1 to 9 of 9
    Jun 2013
    Campy chain ring shifting problem
    All: I am running a 10sp Campy Centaur group with compact (50x34) chainrings. The 50t ring is a Mirage and the 34t ring is Chorus/Centaur. These are both replacement rings. Since the new rings were installed (several thousand miles ago), when shifting from the 50t to the 34t the chain will sometimes fall between the rings and slip. Usually, I have to shift back to the big ring and then down again; occasionally I have to dismount and seat the chain by hand. My LBS doesn't seem to know what the cause of this is. I do not remember having this problem with the original Centaur rings, but that may be coincidental, and I'm reluctant to buy new rings unless I'm pretty sure that is the problem. Derailleur adjustment seems fine.
    Has anyone heard of this or had similar issues? Any advice or experiences? Thanks a lot.
    Cheers,
    Andy
    'brifter' is a lame word.
    I've seen that kind of thing happen from time to time, but without seeing your particular bike in the stand i have no idea where to start. I'd bring it by another shop and see if they can find the cause. Most like it's the position of the derailleur or the adjustment. Could also be some compatibility issue w/ the chainrings.
    I work for some bike racers
    and a bunch of skateboards
    Lost in Space...
    Reputation: headloss's Avatar
    Mar 2013
    Any idea what year the front derailleur is? I know that some of the older ones require the FD to be at a slightly off angle but that was fixed in 2008 or 2009... I don't imagine that would cause the problem your are having but it's worth throwing out there.
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    The spacing is different on the stamped vs the machined Campy rings, and they aren't compatible from Centaur down to Chorus and up. Centaur is a little tricky because some Centaur 10 speed cranks used stamped chain rings and some used machined ones. The best way to check is to put the old rings back on and measure the spacing and compare that to what you have now. For some 10 speed cranks the bolt hole on the crankarm is also offset, resulting in a bent chain ring if you install one that's not compatible.
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't %^&* like that since I was an altar boy" Hank Moody
    wim
    wim is offline
    Feb 2005
    As cxwrench has said, difficult to diagnose over the net. But I would try a small adjustment of the front derailleur first. Sometimes, it may well be adjusted to Campy specs (chain on small ring - largest cog and 0.5 mm clearance between inner cage plate and chain), but that setting could be just shy of producing reliable shifts for a variety of possible reasons. Try increasing that clearance just a bit and see what happens (you may have to disconnect the cable). When you think about it, the perfect adjustment is not a specified clearance, but "a perfect shift every time without the chain ever going into the frame."
    If you have some time on your hands and are curious, adjust the derailleur (repair stand) where the chain will in fact come off the small ring and start going into the frame. That way, you have an idea of how much clearance is too much.
    Mar 2007
    Similar experiences have been posted before e.g.
    10 Speed UT downshift problem
    I can get this to happen once in a while if I shift down to the 34 when I'm in the 7th or 8th rear cog (never tried 9 & 10) which is not very often. I though it was maybe me or my bike until I read the above thread last year. Now my brother is getting the same thing on his new Centaur equipped bike and again only if he is on the smaller rear cogs and even then it doesn't happen every time
    wim
    wim is offline
    Feb 2005
    Quote Originally Posted by cq20 View Post
    No doubt this problem can and does occur with Campy UT cranks. But chain-skatiing on the front is really a very common issue that happens across all brands and models of components. Because of this, the solution almost always is a generic fix, not something related to "Campy only."
    Mar 2007
    Quote Originally Posted by wim View Post
    I'm sure it is but as my experience is with Campy only, that's all I can comment on. (BTW, my brother's bike is PT not UT.)
    Maybe or maybe not. I have years of experience in setting up and using Campy and only experienced this fairly recently. I'm confident my set-up is correct (and I have tried moving things around a bit). The problem is that it is intermittent and hence difficult to tie down. My brother gets the LBS to do his set-up and although we have different bikes (Wilier and Bianchi) he also experiences the skating chain on occasions.
    I look forward to the generic, universal fix to this, although it must be said it isn't one of these things that keep me awake at night!
    Jun 2013
    Thanks for the tips and info - this is great. I think I have the old rings somewhere, and between that and FD adjustment I'll try and sleuth out the problem.
    Cheers,
    Andy
  1. Replies: 7
    Last Post: 11-26-2012, 06:30 PM
  2. Chain drops outside on big ring when shifting rear?
    By Turtle Torque in forum Components, Wrenching
    Last Post: 05-05-2012, 08:31 AM
  3. Any shifting issues with 50/36 chain ring combo
    By roadbike_moron in forum SRAM
    Last Post: 11-29-2011, 01:54 PM
  4. the chain is jumping up to the big ring without shifting
    By elamcup in forum Components, Wrenching
    Last Post: 02-02-2010, 11:42 PM
  5. Front shifting problem-slow going to big ring
    By ashwinearl in forum Components, Wrenching
    Last Post: 02-02-2007, 03:22 PM
