Results 1 to 10 of 10
    Sooper Dooper Moderator!
    Reputation: il sogno's Avatar
    Jul 2002
    Campy - Question on switching to lower geared cassette
    I currently have an Campy 11-25 cassette on my Colnago. I want to put some lower gears on the bike - a 12-29 cassette. I know I'll need a longer chain. Can I ride a cassette with a 12-29 range on my Super Record derailleur?
    What if anything do I need to do to get this to work?
    Attached Thumbnails Attached Thumbnails Campy - Question on switching to lower geared cassette-20170805_212552_resized.jpg
    May 2012
    Not sure if it helps but I have done this with both a 2008 10 speed Centaur on a Wilier and a 2013 11 speed Athena on a Bianchi without a problem. With the Athena-Bianchi I was going from 27T to 29T and didn't have to lengthen the chain (although I never use a Big-Big combination), but I did increase the chain length at the next renewal.
    Russian Troll Farmer
    Sep 2016
    What on earth are you measuring in that photo? Chain stretch???
    and, frankly, the chain you have looks like it has plenty of 'wrap' to go from a 25 to a 29. I'm not certain if a campy short cage rear derailleur is ok, but put the new cassette on and see if it works. You can always change the derailleur if it doesn't.
    "L'enfer, c'est les autres"
    Jan 2010
    The RD will be fine.
    Unless that's a fairly new chain then it's always a good idea to put on a new one with a new cassette.
    There's sometimes a buggy.
    One.
    xxl
    xxl is offline
    Moderator
    Reputation: xxl's Avatar
    Mar 2002
    Without knowing the year Super Record to be absolutely certain, you should be fine, according to the Campy folks:
    Technical FAQ with Lennard Zinn: Chain Wrap Compatibility | VeloNews.com
    Feb 2002
    Quote Originally Posted by il sogno View Post
    Depending on how your chain was sized, you may not have to replace it. Campy recommends using the small-small method so if you are not exceeding the wrap capacity of the RD, then a longer chain is not needed. Since you don't give any information about the RD other than "Super Record" (which could be from 1980) you will have to look up the capacity and then see if you are in spec. The RD probably will handle a 29 but it might be an issue if your frame has a short derailleur hanger.
    Jan 2010
    The RD in that image is from pre-2015. Although not that much "pre".
    Despite the legends about Campy stuff, the basic RD geometry for both 10 and 11-speed remained the same and constant from the late '90's up until 2015. It will clear a 30T sprocket when adjusted. The max capacity of a Campy short cage RD has also remained constant at around 34T.
    Confusion has been created by Campy themselves (gasp). They have typically quoted the max sprocket as being the biggest they made at the time. Nothing to do with the actual maximum.
    One.
    Jul 2002
    Quote Originally Posted by xxl View Post
    It's 2013.
    Jul 2002
    Thanks, Kerry.
    Quote Originally Posted by bikerjulio View Post
    Fwiw, I put a 13-29 cassette on my record 10s RD (2005 derailleur, definitely short cage) with a standard crank up front. That most definitely exceeded the specs as written by Campy. It also worked.
  1. Replies: 11
    Last Post: 08-07-2016, 03:17 PM
  2. Lower Lower Back Pain
    By MWPDX in forum The Lounge
    Last Post: 03-06-2009, 08:32 AM
  3. Campy rear der. B adjuster geared pawl?
    By '02 nrs in forum Retro-Classic
    Last Post: 01-13-2009, 09:30 AM
  4. Switching to Campy compact question.
    By ejr13 in forum Campagnolo
    Last Post: 12-17-2006, 05:05 PM
  5. Litespeed Choice - better frame, lower wheels or lower frame better wheels
    By Cool Roadie nom de Plume in forum Bikes, Frames and Forks
    Last Post: 04-15-2004, 10:29 PM
