Results 1 to 2 of 2
    Apr 2013
    Campy Record 10/Super Record 11 crank interchangeable?
    Are the Record 10 and SR 11 cranks interchangeable?
    I currently have a set of SR11 cranks mounted; I'm using the SR bb cups. I've been looking for some compact cranks, and found a set of used Record 10 compact cranks. I'm pretty sure I'll need to switch the bb cups, as I think the SR ones are specific and have a different seal. What I'm not sure of is if the chainrings are compatible; maybe the teeth are different width or something. I'd appreciate it if you let me know.
    Thanks!
    The 10 speed teeth are .1mm thicker, but a lot of people have used 10 speed cranks with 11 speed, and had no problems. I've done it, but only briefly. You will need some Record/Chorus cups that include the inner seal. SR cups have no inner seal.
  1. WTB - Boxes of Campy Record / Super Record components
    By Pierre in forum Components, Wrenching
    Last Post: 02-17-2013, 07:37 AM
  2. Opinion/feedback campy super record 11 ti crank and gruppo
    By singchef in forum Components, Wrenching
    Last Post: 04-13-2012, 08:44 AM
  3. Crank: mixing Super Record Ti with Record
    By Got Time in forum Campagnolo
    Last Post: 06-22-2011, 09:39 AM
  4. Campy record 2011 vs 2010 super record questions
    By Steelman1 in forum Components, Wrenching
    Last Post: 11-21-2010, 07:17 AM
  5. Replies: 2
    Last Post: 02-22-2008, 04:23 PM
Sea Otter Classic
Contest
