Results 1 to 5 of 5
    Reputation: oldroady's Avatar
    Jun 2011
    Campy Square taper Sugino fit?
    My winter bike is a Merlin with pressed in Campy Spindle. the left arm got damaged and would like to simply replace with a Suntour or Sugino that is available. How close is the JIL to the ISO Tapers?
    The rule is perfect: in all matters of opinion our adversaries are insane. Mark Twain
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    It'll be 4.5mm out of whack, per Sheldon Brown
    Square Taper Bottom Bracket Interchangeability
    This, of course, sets aside the issues of symmetrical versus asymmetrical spindles....which may further ruin your day.
    Reputation: JCavilia's Avatar
    Sep 2005
    What he said. Angle of the tapers is the same, but the width is different.
    More specifically, per Sheldon's article, "if you install a J.I.S. crank on an ISO spindle, it will wind up about 4.5 mm farther in than it would on a J.I.S spindle of the same length."
    That might work for you, depending on the actual dimensions of the parts and how the bb fits the bike, or the crank might bottom out and prevent proper tightening of the bolt, or the crank might bottom out against the bb cup. Hard to tell without trying it.
    We are far from pefect,
    But perfect as we are
    We are bruised, we are broken,
    But we are goddamn works of art
    Works of art
    a real member's member
    Jul 2016
    i've mixed jis and iso a couple times without issue.
    i just rebuilt my paramount with a jis spindle and vintage campy crank. it works great
    Jan 2010
    Quote Originally Posted by blackfrancois View Post
    Yes, but that's the "no problem" way because the crank is further out on the taper. OP has the opposite "there may be a problem" way where he could run out of taper or run into interference.
    There's sometimes a buggy.
    One.
  1. Campy Square Taper BB Reassembly
    By gofast2wheeler in forum Campagnolo
    Last Post: 07-31-2013, 06:52 PM
  2. campy square taper bb torque?
    By samh in forum Components, Wrenching
    Last Post: 11-08-2008, 03:38 PM
  3. Campy square taper BB track vs road?
    By Creakyknees in forum Components, Wrenching
    Last Post: 03-28-2008, 05:52 PM
  4. Square-taper Campy?
    By ssmessenger in forum Hot Deals
    Last Post: 06-20-2006, 06:33 AM
  5. Why does Campy still have a square taper interface???
    By Kaparzo in forum General Cycling Discussion
    Last Post: 03-24-2004, 07:43 PM
