Results 1 to 17 of 17
    Oct 2017
    Can I use new (11 speed) wheels on a 9 speed campag bike?
    My bike is old but still in great condition.
    I have heaps of parts laying around so it would be a shame to buy a new groupset.
    With spacers, can I buy a new wheelset (11 speed) and use it or would it run too rough?
    yes, you can use a 9 speed cassette on an 11 speed hub by using a spacer.
    Oct 2017
    Where do I put the spacer?
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by Greatwhite7 View Post
    Behind the cassette.
    Attached Thumbnails Attached Thumbnails Can I use new (11 speed) wheels on a 9 speed campag bike?-cassette-spacer-2.jpg
    -- Warren Buffett
    Jan 2010
    The title says it's a Campy bike.
    All the answers so far refer to Shimano
    It may seem counter intuitive but if staying with 9-speed, a 9-speed cassette will fit a modern 11-speed Campy wheel with no spacers required.
    With Campagnolo, the freehub splining and cassette width has not changed from 9-speed up until today.
    Attached Thumbnails Attached Thumbnails Can I use new (11 speed) wheels on a 9 speed campag bike?-309437d1443091365-campy-specific-can-i-put-11-speed-cassette-9-speed-wheel-d151df87.jpg
    There's sometimes a buggy.
    One.
    May 2014
    Quote Originally Posted by bikerjulio View Post
    If staying with 9-speed, a modern 11-speed Campy wheel will work with no spacers required.
    The freehub splining has not changed from 9-speed up until today.
    I stand corrected.
    -- Warren Buffett
    Jun 2013
    I have a set of 9sp Colnago (Ambrosio) wheels, with maybe 4hrs riding after having Campy hubs serviced 2 years ago. You can have them if interested.
    Oct 2017
    Good to know, thanks mate.
    Oct 2017
    That makes things easy, thanks mate, will try.
    Jan 2010
    You are not following.
    @lombard acknowledged a mistake. He was referring to Shimano.
    NO SPACER EVER with Campy. Is that clear enough?
    One.
    Nov 2014
    Curious, bj. I get it that the splines have stayed the same but what takes up the space on an 11sp freehub when using 2 fewer cogs than designed for? Are you saying that with the cog spacing of 9sp, at the total cassette width is the same as the total cassette width for 11sp?
    Jan 2010
    Quote Originally Posted by GKSki View Post
    Yes. 11 speeds were made the same width as 9. Campy did this in 2 ways. Firstly and most obvious, the spacing between cogs came down. Secondly, the big sprocket was dished inwards. 10 speeds did this too, but the dishing is a little greater on the 11-speed.
    Basic spacing gives:
    11 spd. 3.76 x 10 = 37.6 mm
    10 spd. 4.15 x 9 = 37.35 mm
    9 spd. 4.55 x 8 = 36.4 mm
    meaning that the big 11-spd sprocket has to dish in by 1.2 mm at most - and no problem, same width as 9-spd and same freehub.
    One.
    tka
    tka is offline
    Jun 2014
    Just to clarify a bit, NO SPACER EVER BEHIND THE CASSETTE with Campagnolo.
    There are spacers between the cogs, and these spacers vary with # of speeds and series of cassette used. Branford Bike has one of the best write-ups describing the differences between Campag freehubs, cassettes, and the spacers between cogs on the cassettes. But there is NO SPACER BEHIND THE CASSETTE on any of the Campagnolo versions.
    Jan 2010
    the whole context of the posts from the beginning, and especially that last one of the OP's was whether or not an extra spacer was needed. I think we all know that spacers commonly go between cogs.
    One.
    tka
    tka is offline
    Jun 2014
    Knowing the type of people on RBR, the first quote appears to indicate no spacers are required even though it is implied that it means behind the cassette. I probably should have quoted that one, but that's what I was referring to. As always, I will bow to your unexcelled knowledge of Campagnolo.
    TKA
    Campagnolo Technical Trained Mechanic
    Oct 2017
    Thats even easier, thanks for that.
    Oct 2017
    Quote Originally Posted by tka View Post
    Thanks all good now, will have a read of that too, cheers.
  1. 10 speed campag shifters with 10 speed shimano deraileur
    By sadisticnoob in forum Components, Wrenching
    Last Post: 02-13-2012, 12:01 AM
  2. Campag hudz, better than current 10sp campag hoods?
    By Campag12 in forum General Cycling Discussion
    Last Post: 08-02-2008, 02:29 AM
  3. Converting a rear wheel from 10-speed Campag to 9-speed Shimano?
    By pretender in forum Components, Wrenching
    Last Post: 06-27-2008, 05:14 PM
  4. Can u use Campag chain on shimano cassette
    By WingNut in forum Components, Wrenching
    Last Post: 10-20-2005, 03:58 PM
  5. Campag 9 speed to Shimano 9 speed
    By Bikecrazed in forum Components, Wrenching
    Last Post: 03-12-2004, 05:32 AM
