Results 1 to 25 of 43
    Road & Trail Warrior
    Reputation: jlandry's Avatar
    Jan 2007
    Can You Remove Tip/Ritchey Torque Key?
    Anyone have success with removing the 4mm bit to replace with another size?
    Reputation: PlatyPius's Avatar
    Feb 2009
    No.
    Other countries need to stop hatin' or we'll unfriend them. - Christine
    Apparently I left my reading comprehension glasses in my ass. - DrRoebuck
    Still, it felt great and I felt like I was sitting on some kind of vibrator -Touch0Gray
    Reputation: Monty Dog's Avatar
    Apr 2004
    Most engineering adhesives soften in heat - try an oven at around 70-80 degrees C
    Reputation: turbomatic73's Avatar
    Yes. Put the bit in a bench vice and pull. It will come out.
    A wheelist
    Reputation: Mike T.'s Avatar
    Quote Originally Posted by jlandry View Post
    No problem. Clamp the bit in a vise and pull. I've done it a couple of times. I don't put other sizes in as I would imagine the torque setting for another size would not be correct. What an excellent tool though - perfect for my many Thomson stems.
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilder's with motivation, information and resources.
    Jun 2007
    Quote Originally Posted by Mike T. View Post
    The torque will be the same regardless of what bit you use.
    Feb 2009
    My "No" was tendered in the interest of protecting his warranty on the tool.
    Plus, bolts of a different size usually have a different torque rating.
    A wheelist
    Quote Originally Posted by Camilo View Post
    Of that I'm completely aware! How could I not be? That's why I wrote "the torque setting for another size would not be correct".
    A wheelist
    Quote Originally Posted by PlatyPius View Post
    He might want to replace a worn-out bit or go to one of a different length.
    Reputation: scryan's Avatar
    Jan 2011
    Thanks dad.
    Perhaps you could warn what may happen if you feel compelled to contribute, instead of just saying "no" until other make you clairify to keep from looking foolish? His choise to void warrenty and all...
    Feb 2009
    Quote Originally Posted by scryan View Post
    Thanks dad.
    Speaking of looking foolish:
    * clarify
    * choice
    * warranty
    Reputation: AvantDale's Avatar
    Dec 2008
    I heated mine up...then pulled the bit out with some pliers.
    Jan 2011
    * clarify
    * choice
    * warranty
    Sorry...
    I generally don't obsess much over spelling unless I have no other point to stand on.
    Aug 2007
    yup heat it with a lighter and pull. i put a t25 torx bit for rotor bolts and zipp stems
    A wheelist
    Quote Originally Posted by reptilezs View Post
    yup heat it with a lighter.
    Mine just pulled out without that.
    Feb 2009
    Sorry...
    I don't need another "point to stand on".... I gave my answer based on what I thought was most responsible. The bit is glued in for a reason.
    ...and I always obsess over spelling. Someone who can't be bothered to spell correctly is probably similarly sloppy about other things.
    Jan 2007
    OK I did it. I put the bit in a vise and pulled on the shank with Vice Grips. Out, no problem. Looks like it's just glued in.
    edit: Thanks everyone.
    A wheelist
    And the SWAT team didn't burst in? You're a lucky boy!
    Reputation: looigi's Avatar
    Nov 2010
    Yeah. Heating works (previously discussed in these forums). I epoxied a small rare-earth magnet inside the the handle so that it retains any bit I stick in it.
    Feb 2009
    Ritchey Rep here to answer all your questions!
    Quote Originally Posted by Ritchey_Dave View Post
    Regarding another thread here on RBR, what are the ramifications of removing the glued-in hex bit on the Ritchey torque key and replacing it with a different size?
    Would it affect the warranty?
    I've read those too. However our manufacturer says not to, and it would void our warranty.
    Reputation: thatdrewguy's Avatar
    Aug 2009
    I've been using the Ritchey version for a while and it works great. I happened to stumbled on the version sold by Giant which has a 4nM rating and comes magnetized with 3/4/5 bits.
    Attached Thumbnails Attached Thumbnails Can You Remove Tip/Ritchey Torque Key?-torque.jpg
    Jan 2007
    When it comes to something so inexpensive, I really don't care about the warranty.
    Feb 2009
    Fair enough.
    Jun 2007
    Ooops sorry. I did misunderstand your comment. I "thought" you thought that a larger bit would somehow alter the torque of the torque key.... which is something I've actually heard said before by people who don't understand how torque is measured.
    Born to chase Ducks
    Reputation: Don4's Avatar
    Jul 2010
    Thanks dad.
    "No." is a complete sentence.
    Quote Originally Posted by MarkS View Post
    I cannot decide whether the seafoam green Lounge kit is cursed or a suit of armor that protects us...like a lycra St. Christopher's medal.
  1. So I got my Ritchey Torque Key and
    By Sablotny in forum Components, Wrenching
    Last Post: 05-04-2012, 06:37 PM
  2. Ritchey torque wrench
    By George M in forum Components, Wrenching
    Last Post: 03-28-2011, 03:03 PM
  3. Remove ultra torque crankset ??
    By Pierre in forum Components, Wrenching
    Last Post: 11-08-2009, 09:24 PM
  4. Proper torque on Ritchey WCS stem?
    By Juanmoretime in forum Components, Wrenching
    Last Post: 04-03-2005, 04:03 PM
  5. torque values for ritchey stem
    By maximum15 in forum Components, Wrenching
    Last Post: 02-27-2005, 07:27 AM
