Results 1 to 6 of 6
    Reputation: shotojs78's Avatar
    May 2008
    cannondale hollogram crank question
    HI,
    on my evo I have cannondale srm on sisl crank (2015) and The crank arms are 170, I would need 175 and I could have a brand new sisl2 arms but not sure if I can fit 2017 sisl2 arms on my 2015 crank? I think the spindle is different now ?
    thanks
    __________________________________________
    2015 Cannondale Super Six EVO (sram red)
    2012 Cannondale Super Six EVO (sram red)
    2012 Cannondale caad 10 (sram)
    2010 Cannondale super six HM liquigas (sram red) sold
    2009 Cannondale caad 9 BB30 Team (sram red)
    2008 Cannondale caad 9 (dura ace) sold
    2007 Cannondale caad 8 (ultegra) sold
    2007 Cannondale six 13 team bb30 (sram red)
    2006 Opus vivace (ultegra) sold
    Feb 2002
    Quote Originally Posted by shotojs78 View Post
    HI,
    Can't help you with your technical question but I should ask why you think you "need" 175mm cranks. There have been numerous studies on this and the conclusion is that there is no formula based on any body dimension that can predict what crank length is best for you. It's all about personal preference and adaptation. Shorter cranks favor higher cadence, and beyond that, nothing else is proven.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    They are the same as far as the spline goes. The offset is slightly different, I think it's about 3mm.
    I'm running an SISL arm on my SISL2 because the one cracked.
    Jan 2017
    Only the spindle length has changed over the years. You should be fine.
    May 2008
    Quote Originally Posted by evan326 View Post
    Ok the spline + the arm's shape, curve.
    Anyway with srm, the spinder is longer?
    Envoyé de mon SM-A520W en utilisant Tapatalk
    Jan 2017
    What??
    I'm saying that the crank arms should attach just fine. They changed from a 104mm to 109mm spindle in 2013 I think. The crank arms are still interchangeable though.
  1. Replies: 0
    Last Post: 02-10-2018, 08:38 AM
  2. Hollogram SL vs Rotor 3D crank
    By motor151 in forum Components, Wrenching
    Last Post: 05-17-2013, 03:50 PM
  3. Replies: 12
    Last Post: 01-24-2012, 05:24 AM
  4. Replies: 0
    Last Post: 01-19-2012, 07:35 PM
  5. Hollogram SL spacers
    By rob southgate in forum Cannondale
    Last Post: 09-24-2008, 08:11 AM
