Results 1 to 6 of 6
    Mar 2013
    Question Carbon Seatpost on a steel frame...
    How to correctly install in carbon seatpost on a steel frame ?
    What kind of grease should I use ? Phil Wood waterproof grease ???
    Thanks.....
    Oct 2011
    Use carbon grease specificly for carbon to any material. Richey sells carbon paste in little packets, tacx sells it, etc.
    Jul 2004
    Depending on the frame and finish on the post.....grease may be fine.
    If the frame tolerance is on the loose side and?or the post has a glossy finish...it may cause it to slip.
    Carbon paste will work better in this case.
    Use something.....the post may get stuck otherwise.
    wim
    wim is offline
    Feb 2005
    Quote Originally Posted by gofast2wheeler View Post
    As said, any grease will do if there's no slippage. "Carbon grease" or "carbon prep" is grease with some grit mixed into it to keep a seat post from slipping. The reason carbon seat posts slip more than metal seat posts is because with carbon seat posts, you can tighten the clamp only up to a relatively mild clamping force.
    The notion that "carbon paste" or "carbon prep" is needed because plain grease would interact with the carbon in some bad way is complete nonsense. But it does sell a lot of "carbon paste," so it serves a purpose. :-)
    Reputation: velodog's Avatar
    Sep 2007
    I've become a big fan of carbon paste, even when carbon isn't involved.
    I have an aluminum stem/handlebar that tend to slip with plain grease, but ever since the use of carbon paste, no problem. I've even been using it with aluminum seatposts and steel frames lately.
    That little extra bite allows me to go a little easier on the wrench.
    Feb 2002
    And that is the ONLY reason to use carbon assembly paste - when things slip if you dont. I've used just grease with CF bars and posts with no issues.
  1. Best seatpost for steel frame and how to buy?
    By discheme in forum General Cycling Discussion
    Last Post: 10-14-2011, 08:25 PM
  2. Replies: 18
    Last Post: 07-30-2011, 06:51 PM
  3. Carbon seatpost on steel frame?
    By estagnitta in forum Components, Wrenching
    Last Post: 03-01-2010, 04:37 AM
  4. Steel frame/carbon seatpost
    By mriddle in forum Bikes, Frames and Forks
    Last Post: 03-25-2009, 06:35 PM
  5. Carbon seatpost and steel frame
    By shinsplints in forum Components, Wrenching
    Last Post: 02-26-2009, 05:52 PM
Sea Otter Classic
Contest
