Results 1 to 13 of 13
Thread: Chain
    Feb 2018
    Chain
    Newbie here folks. Currently (and the foreseeable future) on a Giant Defy 2. Only been riding for about 9 months. Basic question.... How long does a stock chain last? Mileage wise. Rode about 2,000 on my current one.
    Russian Troll Farmer
    Sep 2016
    It lasts until it's elongated to between .5%-.75%.
    "L'enfer, c'est les autres"
    'brifter' is a lame word.
    To quote Kerry, 'how long is a piece of string?'
    I work for some bike racers
    and a bunch of skateboards
    xxl
    xxl is offline
    Moderator
    Reputation: xxl's Avatar
    Mar 2002
    Quote Originally Posted by Giant331 View Post
    The mileage expected from a chain varies so much across riders, due to riding conditions and maintenance practices that it's hard to give a ballpark estimate that couldn't easily be off by a thousand miles or more, so the go-to test is to get a good ruler (metal ones are favored), and measure 12", starting from any chain pin; at the 12" mark, a new chain will have a chain pin exactly 12" away from whatever one you started on. As the chain wears, this distance increases, and at about 1/8" "extra" length, you should get a new chain.
    There are tools made to measure chain wear, but there are lots of folks who don't think they work well (do a search on "Park chain tool" and you'll see the arguments), and most would agree that the ruler method works.
    Donald Trump has never had a wife he didn't cheat on.
    May 2014
    Generally speaking if you wait until shifting is poor you waited too long. Keep your chain clean and lubed and it will last longer.
    If you buy a cheap chain it will not last as long. If you don’t clean or lube your chain it won’t last long. Chains are cheaper than cassettes. People use many different types of lube.
    Reputation: Lombard's Avatar
    May 2014
    The best answer to this is - it depends.
    It depends on whether you ride on only paved roads or on dirt.
    It depends on whether you ride only in fair weather or in rain.
    Hopefully, this will not turn into another thread about whose choice of chain lube is best. We have too many of these already. I will just tell you that our very well respected Mike T. in our Wheels & Tires forum has a very simple home brew he uses that he got 11,000 miles on his last chain. You can read about it here:
    Chains
    YMMV.
    And as others here have said, the best tool for measuring chain wear is not some special tool, but the humble ruler.
    Road Warrior
    Reputation: n2deep's Avatar
    Mar 2014
    The best answer to this is - Mike T. in our Wheels & Tires forum has a very simple home brew he uses that he got 11,000 miles on his last chain. You can read about it here:
    Chains
    YMMV.
    This article is all you need to know about chains Thanks Mike!!!
    Yup, it's the only answer.
    OP, as an extreme example: I've cooked chains in 700 or so miles on my cross bike that gets used in wet dirty conditions and the style of riding that's prone to suspect shifting habits. The chain on my trainer only bike is going fine after about 5000 indoor 'miles'. And given there there is no coasting at all on the trainer, that's a lot in the context of comparing to outdoor miles.
    Feb 2002
    Quote Originally Posted by xxl View Post
    It's been nearly 20 years since the chain/component companies changed this to 1/16" elongation. THat's 0.5% elongation.
    xxl
    xxl is offline
    Moderator
    Mar 2002
    Yes, typo on my part.
    Jul 2012
    Based on all the previous responses, the right answer is - It Depends. But This Tool could help you decide when it's time.
    May 2014
    Quote Originally Posted by Methodical View Post
    This tool is better and you probably already have one:
    Reputation: Srode's Avatar
    Aug 2012
    How did I know that was coming.....
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
  1. Chain, chain, chain...
    By brujenn in forum The Lounge
    Last Post: 07-30-2009, 05:59 AM
  2. Replies: 3
    Last Post: 10-01-2004, 08:00 PM
  3. Chain mileage? (and other chain queries)
    By TrevorInSoCal in forum Fixed/Single Speed
    Last Post: 05-18-2004, 08:50 AM
  4. chain rubs on large chain ring when in 4 smallest rear cogs
    By mdevos in forum Components, Wrenching
    Last Post: 04-14-2004, 10:26 AM
  5. 96 Links of chain on by bike, 96 links of chain..
    By hrv in forum Fixed/Single Speed
    Last Post: 03-22-2004, 08:44 AM
