Results 1 to 2 of 2
    May 2013
    Chain compatibility questions..
    ​1)I recently upgraded my 10 spd stock tiagra chain to dura ace chains.
    Only to find out that the chain the shop gave me were 11spd dura ace ones.Will this cause an issue on shifting? What are the pros and cons?
    2)Another question I had was aesthetically I really like how the new 11 spd Ultegras cranks look like. If I upgrade my cranks to 11spd and retain my current shimano 10 spd groupset - will it work fine? I am just changing cranks. Will I need to change chains?
    Feb 2002
    Quote Originally Posted by littlepitboy View Post
    No issue with shifting. Con is that the DA chain is a lot more expensive. Pro is that it is a little bit lighter.
    You can run a 10s chain on 11s cranks and everything will work fine. It sounds like you are spending a lot of $$ for no improvement in performance on a bike that maybe came stock with Tiagra? Consider just saving your money and buying a better bike.
  1. Chain compatibility questions
    By littlepitboy in forum Beginner's Corner
    Last Post: 07-02-2013, 06:39 PM
  2. Shimano Compatibility Questions
    By Tri Slow Poke in forum Components, Wrenching
    Last Post: 05-31-2012, 03:08 PM
  3. questions regarding compatibility
    By robertras in forum Beginner's Corner
    Last Post: 09-25-2009, 11:35 PM
  4. compatibility questions
    By AnyWeather in forum Cyclocross
    Last Post: 06-30-2009, 08:34 AM
  5. Chain compatibility?
    By pr0230 in forum Components, Wrenching
    Last Post: 12-31-2006, 09:13 AM
Sea Otter Classic
Contest
