Results 1 to 6 of 6
    Mar 2012
    Chain Length calculator
    I recently swapped a 50/34 to a 52/36. I've been reading I need to add 1 inch to the chain. If I use this tool Javascript Bicycle Chain Length Calculator
    it seems like my current chain is .35 inches too short.
    How can I tell this is correct?
    The current chain looks to be okay, how can I tell if its too short?
    Aug 2013
    You are making it way too complicated. Don't use a chain length calculator.
    Use big/big plus one or small/small with verticle rear mech.
    Chain too long if in small/small the chain on the upper jockey pulley rubs the chain before it enters the bottom of the rear mech cage.
    It is too short if you cannot shift into (or out of) big/big because the chain is too tight.
    'brifter' is a lame word.
    Quote Originally Posted by crit_boy View Post
    No, this is not correct. Small/small w/ just enough tension so the chain doesn't rub on the pulley cage. NOT vertical. For pretty much all 2 or 3 chainring road bikes this will give the longest chain possible as long as the drivetrain is all within spec. This is the safest/smoothest running drivetrain.
    Don't bother w/ chain length calculators, that's just overthinking a very simple task. Just put the chain on the bike and size it. Very easy.
    I work for some bike racers
    and a bunch of skateboards
    Feb 2002
    This^ Occam's Razor says use the simplest method. Combine a chain length calculator with a chain checker tool and you get errors and confusion. Use the small-small method and a ruler to check chain wear and you won't go wrong.
    Sep 2011
    Seams like we do this a lot. Chain length question followed by 5 different ways to size a chain the wrong way, then CX beats me to giving the correct way to size a chain.
    I've used this simple technique millions of times and never had a chain too short or too long.
    Feb 2002
    Quote Originally Posted by 202cycle View Post
    If I've said it once, I've said it a million times: Dont Exagerate!
  1. Chain length/links calculator
    By AJL in forum Components, Wrenching
    Last Post: 11-10-2009, 10:25 AM
  2. Easiest Spoke-Length Calculator
    By Puchnuts in forum Components, Wrenching
    Last Post: 11-21-2008, 02:50 PM
  3. Gear calculator and chain length
    By links0311 in forum Fixed/Single Speed
    Last Post: 04-17-2008, 10:49 AM
  4. FYI Wheelbuilders: Spoke Length Calculator available free
    By luca in forum Components, Wrenching
    Last Post: 07-20-2006, 01:29 PM
  5. chain length calculator?
    By DougSloan in forum General Cycling Discussion
    Last Post: 04-02-2004, 03:44 PM
